7.2 not reading pan automation
I have had problems with Pro Tools 7.2 not reading pan automation lately. For example, I have track output going to LCR bus going to 5.1 output. Sometimes when region is panned to hard left (for example), it stays going to the center channel no matter what (pan automation was to center before the beginning of the region). If I click the panner (which looks panned left, but sound going to center) in the edit window during the playback of the region, sounds jumps abruptly to left channel. This behavior is not continuous or always repeatable, most of the time pan automation works normally. Then suddenly it doesn't work at all, without any changes done in preferences or elsewhere. I haven't suspended automation playback on any track. Any ideas? I have done all the normal trashing and restarting.
I'm using Pro Tools 7.2 cs2 / HD2 + 1 Accel / PowerMac / MacOS 10.4.8, sound coming out of ADAT outs of 96 i/o. The plug-ins should be up-to-date. |
Re: 7.2 not reading pan automation
Not sure about that because it works most of time ok with my i/o setup. But I will double check it tomorrow, thanks.
Jim, I think you were right. My 5.1 output was using SMPTE order, which I prefer, but my 5.1 bus before the output was accidentally using film order. Funny thing is that it still worked normally most of the time, go and figure. Thanks again!
This is a known bug. Do a search for this on this DUC, and you'll see it covered plenty of time. There are some work-around fixes as well indicated in these links
it -seems- to be a bit more fixed in cs2. -cd |
After correcting my 5.1 bus orders, I unfortunately noticed that the behavior is still there. Charles, I did a search before posting, but didn't find anything about this bug. Only some complaints that pan automation is late etc. Could you (or somebody) give me some link to thread(s) about his bug, I am very interested in finding workarounds? Also, does anybody know if this pan bug is still in 7.3? If not, that alone would be a sufficient reason for me to upgrade.
OK, here is one workaround told me by colleague: hit suspend automation button twice. It seems to help, for a some time at least. But this is really something that Digidesign should fix soon! I heard it's happening on 7.3.1, too. But maybe only in 5.1 sessions?
EQ3 Not Reading Frequency Automation | RubyQueen | RTAS & TDM Plug-ins | 4 | 03-17-2014 05:12 PM |
PT ONLY reading 1GB RAM please help! | nate9 | ICON & C|24 | 5 | 03-17-2009 09:23 AM |
Not Reading Pan Automation | musixlifestudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 10-10-2008 05:16 PM |
Xpand! not reading automation | Ray Lyon | Virtual Instruments | 0 | 09-23-2006 01:39 PM |
Not reading MIC!@$........ | sirreal06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-30-2004 08:08 PM |
