#21
Re: Laptop Pro Tools users at 100% CPU load - UNIT
However, why not just let Windows Laptop users disable powersaving features?!! Wouldn't that prevent the problem in a more efficient manner? (Unless you at Digi are worried about lots of boneheads not disabling power management and then having PTLE run poorly...) Gorka |
#22
Just loading the processor doesn't sound like a very elegant solution. Perhaps there is another way to prevent the processor from switching speeds. Maybe change the registry key for the 'laptop processor' so windows wont use speedstep when protools is run. Or find the registry key (or service) that controls the frequency of the cpu and make sure it is always the maximum while protools is running. I'm not a programmer, your guys should have better ideas than me!!!
The bottom line is that the solution Digi engineers came up with to fix the speedstep problem you mentioned is causing other serious problems that need to be remedied. Hopefully your engineers can spend some time and find a solution which doesn't cause anything else to go wrong. I have a brand new Dell 700m which has this problem. I dont think the heat is an issue. I think the process digi uses to run the processor at 100% just tricks windows into thinking it is loaded but doesn't actually load the cpu. Some laptop manufacturers have the fan come on when the cpu is at 100% and some (like the thinkpad) use the fan only when the temp rises enough. That is manufacturer specific, but like I said, a better solution would be not to trick windows into thinking it is seeing 100% load. Thanks for being so responsive in this forum, Martin |
#23
martin |
#24
Let me repeat this tricky part: the fans DOES NOT start because you force the processor to 100%. The fans start because the processor runs very hot during 100% load and therefore the fans start. 100% CPU utilization is NOT the same as maximum CPU clock frequency, but yet you seem to think so. All you need to do, is to let the user know, that Digidesign only supports PTLE on laptops with SpeedStep/PowerNow features disabled. That way we can disable the feature ourselves and run the laptop constant at maximum CPU CLOCK FREQUENCY. That does NOT put the CPU in 100% utilization AND PTLE has the maximum powers of the laptop available. All of the time. This is certainly the way to do it - not the other way around. Man, i'm surprised of the way Digidesign chose to do this. I sure hope this can be changed. Please /Henrik |
#25
Is it easy to disable SpeedStep/PowerNow? Does it require going into BIOS?
#26
As for my laptop, I can disable powersaving features by adjusting Windows power settings to "Always On". There has got to be a more optimal way to deal with this problem than just maxing the CPU out!!! I thought my laptop would burn up, so I bought a laptop cooler...it helped a little... -Gorka |
#27
Bumpity bump
#28
I can cook breakfast off my laptop while using protools...seriously. PT's and laptops = sterility
#29
Hey folks,
We have not stopped looking at this issue. I met with some developers today and we are investigating some workarounds for you. Stay tuned. Digi ETS |
#30
Thank you Digi.
We need a good work around for this issue. Lets keep this post at the top of the list guys... |
UAD Users UNITE! | GovrCheeze | Pro Tools M-Powered (Win) | 1 | 02-21-2007 12:47 PM |
Quicksilver 733 users, unite! | leftalive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 02-03-2004 10:00 AM |
Quicksilver 733 users, unite! | leftalive | Pro Tools TDM Systems (Mac) | 1 | 12-25-2003 12:37 PM |
Mackie HUI users unite | digigirly | Tips & Tricks | 4 | 10-29-2001 03:07 PM |
01v users of the duc unite or anyone who may know this answer | fake | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-10-2001 06:32 PM |
