Old 06-12-2012, 10:56 AM
TheJamsh TheJamsh is offline
Default Pro Tools not quitting properly, still active in Task Manager.
This is frustrating, when exiting a Pro Tools session, ProTools.exe*32 is still running in Task Manager, and no matter how many times I try, I CANT end the damn process...
Any clues as to why that is? I suspect this is the reason I'm having issues changing sample rates between sessions with my Focusrite Saffire interface.
EDIT: Okay, five minutes later and the Process has gone from Task Manager, but why does it take so damn long?!
www.anvilaudio.co.uk - PC Users: Buy Skootch, you won't regret it.
PC: Windows 7 64-Bit, ASRock Extreme 4 x79 Mobo, Intel Core i7-3820K @3.6Ghz, Kingston HyperX 16GB Ram, OCZ Vertex 3 64GB SSD, WD Caviar Green 2TB HDD, GeForce 560Ti GPU, SIIG TI Firewire Card, PT Keyboard.
O/B: Focusrite Liquid Saffire 56, Focusrite Liquid Mix 32, Alesis D4 Drum Module, Alesis MIDIVerb4, M-Audio Axiom 49 v2, M-Audio BX8a's, Audix DP7
Old 06-12-2012, 12:09 PM
TOM@METRO's Avatar
Default Re: Pro Tools not quitting properly, still active in Task Manager.
What exact PT version?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 06-13-2012, 02:49 AM
10.1.2 if that helps.
I quite frequently see a pop-up box with "Pro Tools did not shut down correctly, you need to restart your computer"
All because I can't end the process in task manager, I have to restart. Infuriating!
Old 06-13-2012, 07:26 AM
philgrab philgrab is offline
It's an issue with failed ASIO drivers not releasing in x64 Win7. It happens with Sonar X1 as well. It keeps the program hung. You have two options, reboot or just wait the 4-5 minutes it takes Windows to figure out it has a failed process and it will clear on its own.
Old 06-13-2012, 08:41 AM
Thanks, at least I know what's causing it. I'm about to do a complete reformat anyway thanks to Avid's latest 'update', so we'll see if the issue still occurs there.
Old 06-14-2012, 07:52 AM
Milko71 Milko71 is offline
I'm pretty sure it's the Liquid Mix. I have the same problem. When using the Liquid Mix in a session, closing PT and the process still in the Task Manager. When I don't use de Liquid Mix in a session the problem doesn't occure.
I have sent an email to Focusrite Support. They say it's an known issue with the Liquid Mix, but because the Liquid Mix is end-of-life (or will be soon) they don't gonna fix it!
I've tries some utilities to kill the process, but without any succes. I have to reboot or wait for 5 minutes.
Best regards,
Milko
Old 06-15-2012, 02:57 PM
Best regards,
Milko
Ah so that's what it is! Thanks Milko!
Out of curiosity, do you know if the older versions of Liquid Mix have the same problem? I might try a few of those and see if it works better. Such a shame it's at the end of it's life, it's a great little unit!
Old 06-16-2012, 08:42 AM
mlemos mlemos is offline
hi,
i'm not sure that it's a driver problem. it didn't seem to be in my case because it would happen whether i was using ASIO or my 002.
in my case the problem completely disappeared when i updated to 10.2...hasn't happened since.
regards,
marco
Old 06-19-2012, 02:52 PM
I tried version 3.0 and version 2.3.16 of Liquid Mix. I have the problem in both versions!
Old 06-22-2012, 06:51 AM
dope5050 dope5050 is offline
I got the same problem. Bug report?
Pro Tools 10.2 freezing windows. No task manager. Drywsef Windows 14 06-14-2012 07:21 AM
TASK MAnager not showing properly PT 8.1cs2 kd_special Post - Surround - Video 1 01-06-2011 06:42 AM
Pro Tools 8 Task Manager frozen, won't do any tasks! kingtinker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-09-2009 12:31 PM
Pro tools shows up in task manager but does not boot willl3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-20-2009 08:00 AM
Task Manager SKYHIENTERTAIN Pro Tools TDM Systems (Mac) 6 10-28-2008 11:13 AM
