JAMLAB - Input Line level very weak - PT 7.3.1 cs4
Hi, I've just bought a JAMLAB USB interface and hooked it up to Pro Tools M-Powered 7.3.1 cs4. Whilst is great for listening back to stuff I've already recorded using my MBOX2 in PT LE 7.3.1 cs4 if I choose to record through the JAMLAB the input line level is totally unacceptable. I've plugged in a guitar via a Zoom pedal cranked up and even with the input level on the PC on max my highest input register is -16.1, and this is with strummimg chords. With finger picking it's -29.3 Does anyone know what's going on. I thought the point of the Jamlab was that you plug straight in and record guitar, but with these sort of input levels you'd need a mixer or another preamp to boost the signals which can't be right surely. What am I missing here? Admittidly I really only bought the Jamlab to be able to mix and edit some stuff without having to lug roung the MBox2. But I also thought that it would be good for knocking down some ideas and not getting caught out by not having an interface in my bag. What's the story - can you record guitar JUST with one of these or is it a case of "You just need a Pre amp!" And in that case, why isn't the Zoom pedal enough? Some thoughts please, cos this Jamlab seems like utter [bleep] for recording. I could get the same signal plugging in to my laptop via the 1/8' mic socket on the built in soundcard. JazzyJ
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
Re: JAMLAB - Input Line level very weak - PT 7.3.1 cs4
What zoom pedal is it specifically? It's hard to give you advice without knowing all of the facts.
I've spoke to M-audio, they say that it's not normal to have such a low input signal. After trying different USB ports and also trying the Jamlab in WAVELAB as well the results were the same. M-audio say, send the unit back to where you bought it from. I have no choice but to do that and wait and see if a new one works better. As for the guy asking "what zoom pedal is it specifically?" The point was that even with the signal 'pre amped' (via the zoom pedal) the signal was still low. The question is about 'input levels' or lack of them via the Jamlab. Thanks anyway JazzyJ
Here ya go mate, here's the key to your understanding: "I've plugged in a guitar via a Zoom pedal cranked up and even with the input level on the PC on max my highest input register is -16.1" Notice the phrase "cranked up" But thanks for your help, but you really should read the problem properly before offering advice. I've been using Pro Tools from Audiomedia III, Digi 001, Mbox, Mbox2 and now some M-audio stuff, from PT 5.1 up to PT 7.4 on PC and MAC 0S9 and OSX and when I write in to the DUC with a problem I write it clearly. Thus the phrase "Cranked up" implying lots of gain. In this case M-Audio are saying that the unit is likely to be not working correctly. But like I said, thanks for your willingness to engage. cheers JazzyJ
002 Rack Line input low level | beastie boy39 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-13-2008 11:30 AM |
JAMLAB - Terrible recording Level on two new units | JazzyJ | Pro Tools M-Powered (Win) | 10 | 03-10-2008 11:37 AM |
Mbox line level input noise using keyboard | egraham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-03-2003 08:09 PM |
can i run a line level into a hi z input ??? | skyking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-17-2003 02:37 PM |
Digi 001's line level inputs 3-8. Control input? | dcarlson247 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-26-2001 02:04 PM |
