Old 04-04-2006, 01:08 PM
the_dr38 the_dr38 is offline
Default Digidesign this is UNACCEPTABLE performance
I have a HUGE session that I need to master for somebody which I cant now open due to PT suddenly not allowing me to open ANY session and causing an array errors such as an unexpected application error or an access violation error. 7 has now been out for long enough for you to have developed an update whereby it can open on ANY up to scratch PC - especially seeing as the previous versions run so well. My only option now is to send the files to a friend to open (hopefully) the session and save to a 6.x version format and retreat to that session. I have now tried reinstalling windows XP, PT, uninstalling EVERYTHING else on the system, disabled everything else such as audio cards and followed the 7 - tweaking post down to the last word and I still cant open it. I have a standard P4 with the 845 chipset, 1.5 gig of kingston RAM, an 80 gig boot drive, a 200 gig seagate barracuda drive. I have also spent the afternoon on the phone to your helpline which proved no use. I am not happy what can I do? I have a job resting on this? Please help me this is serious for me.
L.Dudley
Old 04-04-2006, 02:24 PM
illone illone is offline
Default Re: Digidesign this is UNACCEPTABLE performance
Good Luck.. we have been posting very similar posts for the last two weeks. and have gotten no where. good luck to you!
Old 04-04-2006, 02:37 PM
DigiTechSupt's Avatar
Are you getting any specific errors when opening that session? Can you see where Pro Tools is at in it's launch sequence when an error occurs?
Have you absolutely verified that all installed plug-ins are PT7 compatible?
Avid Audio Tech Support
Support FAQ
Old 04-04-2006, 02:48 PM
Hi, I am only getting an access violation error after PT has finished loading. Occasionally I am able to get past this point and open up a session and it fully loads - then after the load box has finished and disappeared I get the general application error message which then forces me to quit PT before actually being able to do anything. All of my plugins are definately PT7 compatible.
Old 04-04-2006, 03:51 PM
I finally got the session open and decided to bnc it but when I tried to change my Digital source to ADAT in the hardware setup menu it totally skimped out again.
Old 04-04-2006, 10:18 PM
If you have Waves plugins, you must update them or they will stop PT7 in its tracks(bad pun). My version 7 install went fine and the first couple of sessions opened and played fine but by the 4th session, it started to lock up. I uninstalled Waves and everything else ran perfectly from then on. Re-installed Waves and ran the updater and have had no troubles since then.
Old 04-05-2006, 01:34 AM
Where do I get the updater? I have got V5 waves already.
Old 04-05-2006, 01:46 AM
rocktron rocktron is offline
common sense would suggest you look at the waves web site.
Old 04-05-2006, 02:07 AM
Silly me for not hinking that. It only gives you version 5 which I already have.
Old 04-05-2006, 03:32 AM
and if you look a little harder, you will find the Waves PT7 Update
ILOK! this is unacceptable bacchus40 Pro Tools 10 41 06-12-2012 02:37 PM
LATENCY Unacceptable! Need a solution Jj Cichon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-27-2007 10:04 PM
Unacceptable inaccuracy Compression Records Pro Tools TDM Systems (Mac) 2 08-09-2005 11:30 PM
Mix+ and 6.4.1 = Unacceptable plug-in count? mikejavo Pro Tools TDM Systems (Mac) 6 09-22-2004 09:40 AM
I find Digis Faults Unacceptable whos with me? mxsoul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 36 10-20-2003 07:03 PM
