how does Heat work?
Sry, but i have a question...
How does Heat work... I activate heat in the options menu... I mark heat in the list on the lower left corner in PT....so i see Bypass or Input selection... On the lower right corner i select Heat to show up... Everything works, but i thought heat works also with individual channels... and not only as master effect... is this wrong? and if not, how can i use heat on individual channels... I am a little bit stupid... thanks for help |
Re: how does Heat work?
Heat has a global setting. You have pre and post per channel. Do you have it set to displayed on the channels in the mixer?
Sent from my iPhone using Tapatalk Pro |
Check out the HEAT section of the PT Ref Guide.
You can show/hide the HEAT Master Controls to globally enable/disable/bypass or adjust Drive/Tone (pg 981) or show/hide the HEAT Track Controls to set Pre/Post/Bypass per track (pg 982).
• linkedin •
Thank you very much... for the link and explanations
Now i get it... |
C 24 doesn't work properly with HEAT | Blues Bird | Pro Tools 12 | 5 | 07-29-2015 09:24 PM |
Does HEAT work in Pro Tools 10. AAX? | Apathyrules | Pro Tools 10 | 19 | 12-16-2011 01:19 AM |
HEAT - Avid, when will it be AAX? Will it work on HD|Native? | anguswoodhead | macOS | 17 | 11-05-2011 02:26 PM |
Why doesn't the HEAT trial work on PT9? | saturdaysound | Pro Tools 9 | 7 | 01-05-2011 09:20 PM |
Trouble Getting Heat to Work | seangould | Pro Tools TDM Systems (Mac) | 2 | 09-24-2010 04:46 PM |
