batch conversion 32bit to 24bit
hello guys, can you please guide me to a program that i can do batch conversion of many drum loops that were recorded in 32bit to 24bit so i can use them in pr tools. THANKS FOR YOUR TIME!
dual opteron 280,4gb ram, win xp sp2,digi002, pt le 7.0 |
Re: batch conversion 32bit to 24bit
I don't have an answer for you, but I'm curious; where did you get loops at 32-bit? And why were they produced at 32-bit? I mean, I understand the technical advantages of 32-bit, but it's definitely not an audio standard, and definitely not an expected bit rate, either by the programs or the people that use them. Just makes me curious as to why someone would create them that way in the first place.
You could try Adobe Audition. I know it does batch converting. Not sure about 32 to 24 bit.
Cheers,
spkguitar i know what your saying my friend, and i dont see the need for it, but i bought these loops from a studio in the mid east, and i did not know that they were 32 bit, thinking like you that almost most people record with 24 bits....so no idea? i have adobe, it does read them, but it will take me for ever to convert them one by one, maybe im out of luck...
There's supposed to be batch conversion capability in Adobe Audition, not sure if it's all versions. There is even a template you can set up to name the files.
Cheers,
Sound Forge 9 has a batch conversion process and it will also deal with 32-bit files
003r/i7-930/LE 8.0.1 cs2 on xp |
Recording: 24bit vs. 32bit float | WombatStudio.Org | Tips & Tricks | 55 | 10-05-2014 03:41 PM |
Sample Rate not matching 32bit & 24bit | john1192 | macOS | 0 | 03-15-2012 05:28 AM |
24Bit dithering in a 32Bit session. Any problems known? | Franco1967 | macOS | 4 | 12-22-2011 12:50 AM |
Is it sonically destructive to convert 32bit .wav files to 24bit .wav? | Violet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 06-25-2010 07:41 AM |
32bit.wav to 24bit sdII | neuman | Pro Tools TDM Systems (Mac) | 0 | 05-08-2000 10:44 PM |
