Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Closed Thread
Old 10-16-2020, 03:37 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: I ilock not working
Originally Posted by 2023speaklife View Post
I know that I moved it there because my ilock wasn't working all the time
If Pro Tools isn't seeing your license in iLok Cloud, you should Close Your Cloud Session in iLok License Manager. You can then then either Open Your Cloud Session (to refresh the license) or activate the license to your new iLok USB Key.
linkedin
Old 10-16-2020, 03:42 PM
Default Re: iLok not working
I didn't I don't know what happened
Breaking it down for newbies
Step 1-You need to do this(disable Power Management on all USB ports, called "USB Root Hub" in Device Manager) if you want to use an iLok(or anything USB with Pro Tools). This is a standard Windows system tweak for Pro Tools. You don't want Windows deciding to shut off the power to USB ports because that is what powers the iLok(and maybe your interface or a USB hard drive).
Step2-(after doing step 1), connect your iLok and open the iLok Manager software and see if the iLok shows up on the left hand side(see screen shot for example).
Step 3-as jeffro said, end your cloud iLok session, which will put your PT license back into the "Available" section of your iLok software(see screen shot; red arrow) and then allow you to move the license to your iLok(see Step 4).
Step 4, if you see your PT license in the "Available" section, drag and drop it to your iLok on the left hand side.
Old 10-16-2020, 04:03 PM
It's a Mac, no USB power management settings needed/possible.
Old 10-17-2020, 10:05 AM
2023speaklife 2023speaklife is offline
Originally Posted by Darryl Ramm View Post
But all this is a waste of time, as Jeffro points above... if you moved your licenses to the cloud, it won't be on you iLok, it will have been removed from the iLok and is now "in the cloud". Kinda a basic point. But if you did not do that, can't do what he suggests, please reply to his post.
I know that I am not stupid I want to move them back to the ilock but I can't because it's not recognized by my computer and I am on a mac not a windows
Old 10-17-2020, 10:08 AM
I am really have a problem and I been using my ilock for over a year and it stopped working and I barely got it to work to get them off (my licenses) now if I try to move them back the ilock is grayed out
  #16
Old 10-17-2020, 10:16 AM
Originally Posted by sw rec View Post
Did you disable usb power management?
  #17
Old 10-17-2020, 10:19 AM
Originally Posted by crizdee View Post
Have you got the latest ilok manager installed?
Can you view the contents of the ilok and see your pro tools license using the ilok manager?
no I can't it's grayed out
Chris
  #18
Old 10-17-2020, 02:08 PM
Sorry, but I missed that detail
  #19
Old 10-17-2020, 02:56 PM
Yes but you are wasting everybody else's time here by not even bothering to explain what you have done or are trying to do. Nobody can guess you've been having problems before, have moved to the cloud etc. And yes I know you are on a Mac, I just pointed that out. Now two pages into a thread and just going around in circles... and the most basic info is not clear... like when you talk about the iLok... are you talking about the new or old iLok. Is the new Ilok seen by ILM and can you add that new iLok it to your account? (did you do that before trying to move an license to it?... we have no idea how much stuff you know or what you are doing, we only know what you actually tell us.)
There is nothing here that should take more than 30 minutes or so to work through before giving up and contacting Pace support or testing with a clean macOS install. But you need to get your act together, and if you want help here you really need to work on describing stuff clearly.
  #20
Old 10-20-2020, 09:14 AM
ok I did I couldn't get my old ilock to work and so I reinstalled to ilock maniger and it worked for a bit just long enough to get my licents off and move them to the cloud and not I decided to buy a new liock was getting it set up now it's not being reconized like the old one... so I was told to do an os upadate and an a protools update and that what I waiting to see if that will fix it
Last edited by jeffro; 10-20-2020 at 11:41 AM. Reason: Removed screenshot - best to not show account info & serial numbers on a public site.
Closed Thread
ilok working on new MBP with usb 3 stevedresser83 macOS 8 11-21-2013 08:41 PM
Strike 1.5 upgrade - not working because of iLok-working now gryphondale Virtual Instruments 0 01-27-2008 09:23 AM
ilok working? detroitkruk Pro Tools TDM Systems (Mac) 5 08-02-2005 07:24 AM
USB / ilok not working blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 12-31-2004 07:08 PM
ilok driver not working on brand new ilok, help! joybeanstudios Pro Tools TDM Systems (Win) 2 05-30-2004 09:40 AM
