Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Mac OS X
Old 10-27-2013, 02:34 PM
Piers Gibbon Piers Gibbon is offline
Default PT 10.3.4 works fine on Air but Express won't..
Everything fine in the voiceover studio with the MBP
And all fine when I use my (studios oldstyle ilok and) PT 10.3.4 on my 10.8.5 MBA 13-inch, Late 2010
But now I have bought an Avid Fast Track solo (plus new style ilok) and Express PT 10.3.4…it got me to uninstall the full fat PT on the Air…but won't start apart from flash briefly on the splash screen…
I have used Protools Prefs Helper to trash the default set
But no joy
Any ideas?
www.piersgibbon.com
www.soundcloud.com/piersgibbon
VOICEOVER - Avalon 737sp/Focusrite Saffire Pro 40/Neumann + Rode inside an Esmono voiceover studio (+ Source Connect, Prima LT, Sonifex TBU, Sonnox plugins)
Record: MBP 13 inch mid 2012, 2.9 ghz i7 8gig ram, PT 11, GDrive Professional Ext Hard Drive
Backup:15 inch early 2008 MBP, OSX 10.10.2
(+Windows 7 PC running Audio TX isdn and tbu codec)
Edit: PT Express 10.3.4 on 13-inch, Late 2010 MacBook Air, OS X 10.10.4
Old 10-27-2013, 02:47 PM
Default Re: PT 10.3.4 works fine on Air but Express won't..
if I remove the ilok and start PT Express it does at least tell me to put the ilok in…but still dies before even a single message on the first splash screen
www.piersgibbon.com
Old 10-29-2013, 12:53 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
I would start with these things...
  1. Go to www.iLok.com
  2. Download the latest iLok License Manager and install it. This will not only install the latest iLok License Manager application, it will also install the latest extensions needed for Pro Tools.
  3. See the Known Issues link on the home page of iLok.com, and follow the instructions exactly for "Repair & Sync"
After that, check to make sure your Pro Tools Express license is showing as activated on the iLok you are using.
You also want to make sure you have installed the latest drivers for your Solo:
www.avid.com/drivers
And last, if none of that helps, redownload the Pro Tools Express installer from your account at http://account.avid.com under Your Products.
Bruce Paine
System Details
Old 10-29-2013, 01:42 PM
Thanks so much for your advice
1. I already had the latest ilok license manager
2. I did a Repair and Synch
3. I updated the Solo driver…THANKS!
4. PTE still doesn't start (even after trashing all the prefs in that PT Prefs utility)
So I am downloading PTE again, will uninstall and reinstall
www.piersgibbon.com
Old 10-29-2013, 01:56 PM
and it works! THANK YOU!
On the uninstall I went for the nuclear uninstall option as this laptop has been used with loads of different hardware
Anyway it works and I'm very grateful
www.piersgibbon.com
Old 10-30-2013, 12:47 AM
hmm well it works but I cannot get any sound out of it through the Solo headphone outputs
I think this is also a hangover from this laptop being used with lots of different i/O settings and machines
I'll keep fiddling
www.piersgibbon.com
Old 10-30-2013, 10:26 AM
jbrown7282 jbrown7282 is offline
Open your i/o settings and click default this should bring it back to conform with your current interface.
I always make it a practice to save i/o setups for different interfaces and it is easy to import as well.
Jay
Litehousemuzik
Audio Mixing Services
Old 10-30-2013, 10:35 AM
and you are exactly right…Default button pressed on all the Ins and Outs
and now it works..thanks!
www.piersgibbon.com
Old 10-30-2013, 10:36 AM
Not a problem. Happy Editing!!
Jay
Litehousemuzik
Old 10-31-2013, 01:45 AM
Thanks..yes the MBA now makes a sweet editing rig for the really long jobs, much easier to go back to bed with a cup of tea and scroll along the trackpad
And the FVO who shares the studio now has that option as well
Great stuff!
I don't much like needing to have the Solo with me as a dongle…and it also means I need to connect headphones rather than listen to the laptop speakers (or hang on, maybe I can fix that??)
But for the money it's a good expansion to my voiceover studio
And I can always crossgrade to 11 one day if I miss clip gain or need some more video power
Nice one Avid
www.piersgibbon.com
44.1 works fine but 48 doesn't petmar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-20-2010 05:54 PM
HELP PT works fine one day and not the next! oddeodude2012 General Discussion 1 03-17-2005 12:02 PM
My 001 works fine, should I go 002? jeronimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 08-17-2004 02:02 AM
Nview works fine BUT NOT ON PT anyone? lie-ability 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-09-2003 09:05 AM
My Pc works (now) fine with PTfree--> jdmatt Digidesign Hardware & Software 1 11-04-2000 12:59 AM
