Old 06-28-2012, 08:21 AM
Krzysztof Krzysztof is offline
Default MC Transport losing connection w V-Control-Logic 9
Hello
I am having difficulty running V-Control alongside the MC Transport and was wondering if anyone has had a similar issues...and maybe even a fix.
The V-control seems to hold the connection nicley, but the MC Transport does seem to be able to. One thing that i found was that if one clicks on another application (in my case it was Chrome) and then clicks back to Logic the MC Transport becomes available again. The minute one uses V-Control though the MC Transport goes bye bye again.
If the devs of Artist MC/Eucon could chime in and give guidance regarding whether this is a V-Control/OSC issue or a Artist MC/Eucon issue that would be helpful....maybe it's a Logic issue.
Regards
Krzysztof
Old 06-28-2012, 09:32 AM
lberrios1962 lberrios1962 is offline
Default Re: MC Transport losing connection w V-Control-Logic 9
I'm a PC user and I can tell you that its not a Logic issue. I had the same issue and others problems with the Artist Control running Protools 10 and Samplitude Pro X. Also I had seen multiple others people here in the forum with similar issues and Avid does not have a fix for the problem yet. I dont even know if they are working on it, at least they havent post anything in regard to the issue.
I dont know how loyal are you to the Avid Artist series but I was loosing customers waiting for a solution, so I returned to the seller.
Good luck!!!
ASUS P9X79 DELUXE, Intel i7 3930K, 32GB DDR3 Corsair Dominator, 2 SATA 1TB 64MB HD, CORSAIR H80 Liquid Cooler.
Mac mini 2.3GHz Quad Core Intel i7, 16GB memory, 1TB Fusion drive, 1TB Thunderbolt external HD.....Running PT11
Old 06-28-2012, 03:37 PM
chris-euphonix chris-euphonix is offline
Are you using V-Control ??
( which I think is an iPad app )
Old 06-28-2012, 08:21 PM
Hello Chris
Yes i am trying to use V-Control (ipad app) with a MC Transport. The V-Control is running through Computer to Computer network i've set up and the MC is running through ethernet #1.
Any assistance would be appreciated.
Regards
Krzysztof
Old 06-28-2012, 09:08 PM
Hello
Just a quick add on to my previous posts:
I've assigned a static ip
MacPro at 10.2.2.1
MC Transport at 10.2.2.2
Netmask at 255.255.255.0
and, both the v-control and the mc transport are talking nice with logic. Early days, but it seems to be holding. Will report any change.
Regards
Krzysztof Szychowski
MC Transport keeps losing connection... BigBongo Artist Series 0 11-21-2012 05:10 AM
MC Control losing connection Trazan Artist Series 7 07-27-2012 04:57 AM
Control 24 losing connection KrisHeinold ICON & C|24 4 12-06-2010 11:22 AM
Control|24 losing Ethernet connection on TDM/XP Echo studios Pro Tools TDM Systems (Win) 2 04-10-2004 08:07 PM
control 24 losing connection w PT firedog57 ICON & C|24 3 02-02-2004 08:23 AM
