Old 11-20-2023, 07:02 PM
tomhartman tomhartman is offline
Default Where are PT Plug ins 2023 on Mac?
PT 23.6.0.110
Seems like I have to look this up every year or so ..this time will write it down
Thanks
Old 11-21-2023, 11:21 AM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
Default Re: Where are PT Plug ins 2023 on Mac?
/Library/Application Support/Avid/Audio/Plug-Ins
I will choose,
Freewill
http://jimdiazaudio.com/
Old 11-21-2023, 11:30 AM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Macintosh HD/Library/Application Support/Avid/Audio/Plug-Ins
Or whatever your Boot drive is named instead of Macintosh HD
I don't remember if Pro Tools installs the Alias in the Plug-ins folder for other plug-ins, but this is what my Plug-Ins folder looks like, which I keep in the Finder sidebar for easy access:
Macintosh HD/Library/Audio/Plug-Ins
Folder List:
AAX (alias)
AAX Unused (alias)
Components
HAL
LV2
MAS
Unused. (for AU)
VST
VST Unused
VST3
VST3 Unused
Bruce Paine
System Details
Old 11-21-2023, 11:36 AM
No luck nothing there...
Old 11-21-2023, 11:40 AM
Admin Emeritus
Are you sure you are not looking in your "user name" Library? Click on your System drive icon and then on the Library there.
Easy mistake to make, I do it all the time.
Or if you did not install Pro Tools for all users, maybe it actually is in your username Library.
Bruce Paine
System Details
Old 11-21-2023, 11:49 AM
Clicked on Macintosh HD.
Held option clicked Library from the GO menu
Application Support
Only shows Avid Link (twice)
And Pro Tools/cache and Cookies.
Geez, can't Avid just make a "Go To Plug Ins" menu command? LOL
Old 11-21-2023, 11:52 AM
Without wishing to be rude, if you can't find these, perhaps you shouldn't be ferreting around in your OS folders.
Spotlight search won't show you these by default.
Use a program like Find Any File to do a search for "aaxplugin".
The path you've been given is correct.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 11-21-2023, 11:59 AM
Admin Emeritus
Yep, I was wrong about Spotlight finding it.
Did a find using Find Any File as Dominic suggested for AIRChorus.aaxplugin and it showed the correct path.
Bruce Paine
System Details
Old 11-21-2023, 12:01 PM
Found them. My mistake was in clicking on the Mac HD and THEN holding option and clicking Library from the GO menu. I just needed to go straight to LIBRARY on Mac HD. Thanks all.
And yes putting an ALIAS in the FINDER lol
Old 11-21-2023, 12:07 PM
Forget spotlight and open Terminal app from Utilities. Issue this command:
Code:
find / -iname '*aaxplugin'
... and eventually you see the folder where your aaxplugins are hiding.
PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta theodd Avid S1, S3, Dock and Control App 14 10-19-2023 07:23 PM
does 2023.9 work in os10.14.6 if i use the 2023 hd driver? [email protected] Pro Tools 1 09-25-2023 09:13 AM
Pro tools 2023.3 No Playcell plug in Dor.Avitan Pro Tools 6 06-06-2023 05:56 AM
Which plug ins are broken in PT 2023.3 and why?!? Franklyn Pro Tools 23 03-31-2023 08:07 AM
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
