stereo panning
i've got an imac, a mackie 1202 and Pro tools Free. i'm coming directly out of my turntable into channels 11/12. from there the signal comes out of the tape out (RCA) and into my imacs minijack.
i've created two tracks. should their pan pots be left alone at center or panned extreme left and right? thanx... fitz
G5 Dual/10.5.8__ 002R/ PT8.0.1cs2 |
Re: stereo panning
put them wherever they sound the best... i have my drums submixed into a stereo aux track and have them panned not center or extreme, at about <30> or so... makes for a bit wider center in my pan spectrum
are you talking pan on the external mixer? if you are, you might want them hard left and right |
Re: stereo panning
that's correct...
if you want to hear the stereo image in the same width as it is recorded on the vinyl, then set your pans to full left and right. SC
SC When the machine produces tranquillity, it's right. ---Zen and the Art of Motorcycle Maintenance |
Re: stereo panning
i do want to hear the stereo image as it was originally recorded.
thanx again...fitz
Re: stereo panning
I just noticed you have your table plugged directly into the mixer.
Does the low-end seem to be lacking? |
Re: stereo panning
yes, i noticed there was almost no lows, so i boosted both the lows and the mids a little, but it still is lacking. why?
...fitz
Re: stereo panning
To correct the problem with lost low-end from vinyl you should use either:
a) a mixer with phono-inputs (DJ-mixer) b) an amplifier with phono-inputs, and tape-output. c) seperate RIAA-filters to convert the signal from the turntables to a normal linelevel signal...(costs about $20)
What's that? - That's the machine that goes "pling". Bastiaan |
Re: stereo panning
Panning stereo guitar? | imi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-01-2009 10:21 AM |
Stereo Panning | Ling | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-20-2009 12:54 PM |
Panning stereo tracks | shilshoolon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-12-2008 04:15 PM |
Stereo Panning | C | Pro Tools TDM Systems (Mac) | 3 | 05-02-2007 05:58 AM |
stereo panning | Harold Bolder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-09-2002 02:21 PM |
