IK Multimedia SampleTank3 library location issue
I installed SampleTank3 Free and in order put the library on my external drive with all my other audio I had to create an alias in HD/Shared/IK Multimedia/(SampleTank3 alias). I opened SampleTank3 in Pro Tools and refreshed the libraries without any issues. I then attempted to import my own samples, which are located on the external hard drive. If I tried to do this directly, I would get the following error:
Error importing sampling /Volumes/LALLISON/Music production/Luke/Clap/._C1 Clap house.aif. I then tried to be cunning and put an alias in HD/Shared/IK Multimedia/(Luke alias) but the file explorer in SampleTank3 just uses the end path of the alias rather than the alias itself as the folder, which just results in the same issue mentioned above. Is there some way to use all samples on an external hard drive? |
Re: IK Multimedia SampleTank3 library location issue
I don't do much sample import into ST3 but have never had issues when I do. All my samples are on the same external drive that hosts my ST3 sample library. |
I'm happy to hear that you are able to load samples from a different hard drive to the one you installed SampleTank3 on. However, it doesn't work for me. You're right, the alias isn't necessary for the factory library so I've just used the direct path to my external hard drive. It still will only accept imported instruments from the system drive though. I can import from anywhere on the system drive but not the external hd. Could it be to do with he fact the external hd is formatted as fat 32?
I was biting my tongue after your first hostile response but seriously, come down a notch. It's abundantly obvious that I'm using a mac as you've already surmised. You replied to another thread of mine in which I explicitly stated this information a few hours prior to replying to this thread. Feel free to move along if you're getting too frustrated to speak civilly instead of actively seeking things to complain about.
What hostile response have I given you? I spoke honestly and if you can't deal with that then that's not my problem - I don't play politically correct with the precious snowflakes of the world. I know at least one other person that posts regular here who would respond to you in the same way - does the name Darryl Ramm bring anything to mind? I, like a lot of others here do what we do to try and help people but when they won't 'help us to help them' that's when things get testy and questions for info get repeated and help gets delayed. Oh yeah - that thread you're referencing by the way you never responded to whether what was written worked or not. That would have been the 'civil' thing to do. |
I may be wrong, but it seems when I tried to open old Sample Tank full version libraries on ST Free, it wouldn't open them. Seems the free version only opened the select samples you could download. Didn't play with it too much more, so, as I said I may be wrong, but it just might not work.
Save early and often! (or once a day whether you need to or not...) |
IK Multimedia - http://www.ikmultimedia.com |
Why not use a Mac drive format like Mac OS extended (journaled)?
where is the User library default location | bear0328 | Pro Tools 11 | 4 | 05-01-2014 01:19 PM |
Structure Library Location | jbr | Virtual Instruments | 2 | 08-27-2010 01:18 AM |
structure LE library location | Mr.O | Virtual Instruments | 3 | 09-06-2009 02:19 PM |
NI komplete kontakt library location? | crizdee | Pro Tools TDM Systems (Mac) | 14 | 08-11-2009 05:51 PM |
Best sample library location? | RpwBass | Digidesign Hardware & Software | 6 | 01-10-2002 08:15 AM |
