why doesn\'t \"import audio to track\" work now?
i just upgraded to XP and the new LE software, but now i can't "import audio to track", or "import track." how can i remedy this?
Re: why doesn\'t \"import audio to track\" work now?
Give us a little more detail? This works fine on other systems.. so tell us about what you're trying to import.. what format, what was it created with, etc...
Rail
Make sure the imported audio is the same bit depth and sample rate as the session.
www.carvelstudios.com |
Did you get an error message ??
What is it ?? cheers,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
bit depth and sample rate are the same as the session i'm trying to pull it into- 24,48 wav. it's a crash cymbal sound that is a few seconds long from another ptools session that i copied on to my desktop first. even if it weren't the same bit and sample rate, though, it should tell me i need to 'convert.' in the import screen, when i highlight the sound i'm trying to import, it doesn't even register that i've selected anything. it won't read the audio it's supposed to read. WTF. i tried highlighting a bunch of other stuff too, and it won't recognize.
i love my apple iPhone! |
Instead of using the desktop.. use a valid audio drive with a constant path.. and tell us what happens.
What's the exact name and path of the sound file? Rail
yeap... It has happened to me. What I do is open the audio file in SoundForge and save it with other name, try to save it without the "extra information" (like markers etc.) .... then try to import it into protools.
my .02
Camilo Orozco Like us on www.facebook.com/artedigitalestudio www.estudiodegrabacion.com.mx |
Rail
Does "Automatically Copy Files on Import" work with Import Audio command? | leftalive | Pro Tools 10 | 3 | 04-17-2013 09:35 PM |
Import Audio function doesn't work in 8.03 | resway | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 04-02-2010 09:03 PM |
Drag audio files after import doesn't work!!! | tj_davies | Pro Tools TDM Systems (Mac) | 4 | 12-09-2009 02:47 AM |
Import Audio To Track- Preview Audio Does Not Work | Curve Dominant | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-15-2007 07:02 PM |
Import audio to Avid: what formats work? | Zumwalt | Post - Surround - Video | 2 | 08-16-2004 07:50 AM |
