Dongles Dongles Everywhere
Does anyone know if it's safe to daisy chain USB hubs to accommodate the growing use of dongles? I'm up to seven dongles now, and expect to add a couple more in the next few months. Then there is the need to connect the Midi USB interface, my DNS-2000, printer, keyboard, PODxt, iPod.... As long as the Hubs are AC powered, will it be safe and not hose the dongles? I'm all for copy protection, but this is starting to get a little out of hand.
Thanks. Bill |
Re: Dongles Dongles Everywhere
Are some of these Ilok auth's? if so why not place them all on to one Ilok! this can be done by syncing all your ilok's to ilok.com amd moving to one ilok. Just a thought. Or what 9 dongles will you be having?? Chris
For low-powered devices such as dongles, sure - no problem. You can also hang a mini-hub on your keyboard. For longer cable runs, a powered hub is best. BUT - for dongles, it doesn't really matter. USB 1.1 or 2.0 -- either will work.
--Jeremy |
"USB 1.1 or 2.0 -- either will work. "
USB2 Note: I had issues with an adaptec USB 2 hub. with a G5 . It ran at high speed which rendered all I-Lok & Logic keys unreconizable. Went to a 7 port Mac-Hub powered USB 1 and all was fine. |
My logic key was damaged by a powered usb hub. i was able to get it replaced but be careful
What I meant to say, use either USB 1.1 port or 2.0 from your mac. (did you know that the only USB 1.1 port on a late model - last 18 months - G5 is on the KEYBOARD? -- The USB ports on the mac itself are USB 2.0, and there are some incompatibility issues plugging in a USB 2.0 hub to a Mac USB2 port -- if your devices are USB 1.1 -- such as a MIDi I/O) -- I could write a few pages about how poorly Apple has implemented USB, but save it for another thread.
--Jeremy |
Right now I've got a Belkin 7-port USB 2.0 powered hub. My dongles are as follows:
ProTools HD Waves MOTU MX4 MOTU Mach 5 Logic Sonic Studio Korg Legacy Dig. Edition I'll be adding more dongles when the VSL Vienna Instruments are available (at least one if they can be combined, but I'm not sure about that or if it will be one dongle per package). And MOTU's Ethno Instrument down the line. And who knows who else will throw a dongle into the mix in the future. Maybe I can double up on the MOTU dongles, but some times I want to put Mach 5 on a second machine when I'm hitting the CPU a little too hard. Add to this another five or six USB devices. It's just adding up, and for now I'm plugging and unplugging things as I go along. Quote:
Thanks! Bill |
I believe you can consolidate your Waves and both MOTU assets in the same PT iLok. That would eliminate 3 additional iLoks.
Mixing in the box, requires thinking outside the box. My New Instructional Mixing DVD 2 is Shipping www.tonysound.com http://twitter.com/tonysound |
Yes, but if your iLok with the waves assets on it dies, and you send it to Waves to get fixed, they won't replace the MOTU assets, likewise, if you send it to MOTU then you can't get your Waves assets replace. And of course, as we all know if your iLok gets stolen, well then your are just all around SOL.
I think that decentralization is best in this industry. Someday some one will build a USB patch panel for iLoks and other USB based dongles. Just imagine having a 128 point patch bay were you could have all or your dongles attached to your computer at the same time, and not have to replug for whatever app you're using. And the whole things could be locked up and encased in a fire-proof safe with 30inch think steal walls and a giant combination or keyed lock. Yeah it would be about as much fun as moving a Mac truck around with you when you needed to be mobile for a project, but at least your iLoks would be safe--sort of.
Justice C. Bigler www.justicebigler.com Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB 2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre Road/hotel: Roland OctaCaputre / Apogee One |
not very cost effective |
Dongles and DOD | johnnyu | Pro Tools 10 | 26 | 12-12-2012 04:02 PM |
Dongles | Shrackattack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-09-2009 06:55 AM |
Best USB hub for Dongles? | Ru_C | Pro Tools TDM Systems (Mac) | 13 | 03-22-2007 10:18 PM |
Dongles/usb | john a | Pro Tools TDM Systems (Mac) | 3 | 01-15-2002 10:07 AM |
New G4 w. Dongles | Charles Deenen | Tips & Tricks | 1 | 12-18-1999 03:49 PM |
