Old 11-26-2004, 07:59 PM
Nick 5 Nick 5 is offline
Default Volume automation when mixing
I write volume automation to a track and later decide to create a group which includes this track.
I then decide to change the overall volume of the group and notice that the track with automation does not respond to the change.
I know I can select the automated track and use the trimmer tool to move the overall volume automation up or down, but I'll bet there's an easier way to do this. For the life of me, I can't find this in the user manual.
Can you DUCers help me increase my productivity?
Old 11-27-2004, 02:05 AM
BIG D BIG D is offline
Default Re: Volume automation when mixing
Hi Nick,
In that case I would Buss all the grouped tracks to a stereo Aux then automate that aux only. That w ay you can still do single track automations to each of the individual track, then do a group Automation on the Stereo Aux track.
Hope this helps,
Best,
Big D
INTEL QUAD XEON
INTEL S5000XVN serverboard
4 gig Fully Buffered Ram (About to add more)
3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green
NVIDIA Geforce 7300le,
Command 8,HD2,192,Massive Pack 4
Windows 7 64 bit PTHD 9
Old 11-27-2004, 01:16 PM
Big D, thanks for the idea -- this is a good option for an automated track in a group.
Now, what if the automated track is not in a group? Is using the trimmer tool the only way to adjust overall volume of that track, or does someone else out there know of an easier way?
Old 11-27-2004, 01:32 PM
Chris Cavell Chris Cavell is offline
buss just the one track you need to adjust...
Cavell Studios
Old 11-27-2004, 06:02 PM
marcusb marcusb is offline
Kinda kludgy, he needs to be able to alter the level of the entire group including the automated track. If you have say 4 vocal tracks, one has automation and you wanna adjust the overall level of all the vocals i'd bus the lot to a mono or stereo aux and use that to trim the overall level. If your relative balance between all the grouped tracks is good approach them as a single unit.
Cheers,
Marcus
Old 11-27-2004, 07:03 PM
Kinda kludgy,
No, just answering his most recent question:
Cavell Studios
Old 11-27-2004, 11:12 PM
Thanks for the ideas, guys.
Old 11-27-2004, 11:58 PM
edemunari edemunari is offline
Maybe asking to digi, i just post it here on duc before, to improve the volume fader options and consider to make a switch that let you make the fader work in relative mode.
I mean, an option to make the volume fader work as a relative controller and trim the volume of all the track even if ther is already an automation volume on that, this would let us program all the volume changes in automation and then let us trim the overall volume as if there were no auto on the track, lowering and rising the volume of a percentage on all the written automation.
Ciao
Ciao
Eriberto
Old 11-28-2004, 03:01 AM
Already exists as automation "TRIM" mode on TDM rigs.
Marcus
Old 11-28-2004, 11:36 AM
da BaSsTaRd! da BaSsTaRd! is offline
there is a trim plugin that you can insert onto a track. i think its exactly what you're looking for - adjusts the overall volume of the track its inserted on without having to change automation data.
its mono only, so if its a stereo track, you need to select it from the multi-mono list of plugins.
i love my apple iPhone!
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
Mixing with volume automation on tracks amolin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-18-2009 02:42 PM
Volume and Mixing. mmccarrell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-18-2004 09:34 AM
volume control for Mixing in the Box Redmann Pro Tools TDM Systems (Mac) 16 08-26-2003 10:24 PM
mixing after automation Dan Downs Pro Tools TDM Systems (Mac) 4 07-09-2003 02:17 PM
