Re: kick drum leakage! help
Are you mixing a solo kick drum record?
How does the kick drum sound *with the rest of the kit*? A little bleed is totally fine provided it's not causing you any phase problems -- if you are obsessing over a solo'd kick drum i'd suggest you pull up a quick rough kit mix and work on your eq's in the context of the whole kit mix, remember you are recording a drum KIT not a collection of individual drums. If you aspire to be a sound engineer don't fall into the "just replace it with a sample" cop out, learn the craft and spend time working on your mic choice and placement skills you'll become a MUCH better engineer. Cheers, Marcus |
Guys...
Listen to the poster, not to me! This is his original post: Quote:
He has all ready made it clear that the leakage is not "good leakage." The poster has expressed several times that he plans to manually replace every kick hit. He also has not expressed knowledge of the existance of such things as Sound Replacer and Drumagog. These tools would save him HOURS of valuable time. THAT is why I have made the suggestion I have made, as it is exactly what he is asking for, and is his best solution. Using the proper tools for the job is never a "cop out." The posts so far have all contained good advice, but I think a program like Drumagog is the answer to your dilemma. |
As i states on my first post
"If i leave the leakage there, it will make the mix muddy and uncontrolled..". I dont mind leakage at all, but when the mic have been badly placed and cause way to mutch bleed, it makes more damage than good.. Like i said, i'm doing the mix only, not the recording of the instruments. I cant tell the band to go back and record the drums over again, i have to do the best i can with the material i got atm now; i tried ur suggestion sqkguitar, but if i did it right, it didnt help that mutch. If the the samples is the only way out, is there a clever way to do this using the DFHS? How is the most affective way to do this? to get it in 100% time without using to mutch time. Thnx Andy |
exactly alexlakis.
I dont have drumagog, but drumkitfromhell susperior, and i think that will do the same as drumagog, right? The soundreplacer made me curious mate I preciate the help, thnx |
What programs like Drumagog and Sound Replacer will do is exactly what you want to do: Search a sound file for peaks and replace them with a sample of your choosing. These can work in the form of an Audiosuite plugin.
1. Highlight your bass drum track and select the sound replacing plugin of your choice. 2. Choose the dB threshold where you want the plugin to insert a sample. These programs allow you to choose multiple thresholds with multiple corresponding samples. For example, you could use a soft BD sample for a hit that is quieter, and a harder BD sample for a hit that is louder. 3. Create a new track and choose that as the plugins output. Choose 100% mix (meaning that the plugin will output ONLY the sample, not any of the original.) Now click process. This will create a new .wav file with just the sample. You can now mix this in as much as is needed with the original track, or mute the original track and use just the sample track. Here are some links for you! http://www.drumagog.com/default.asp http://www.digidesign.com/products/d...roduct_id=1059 Not sure if Sound Replacer has a free demo, but I'm pretty sure Drumagog does. DKFH and BFD are not "analysis" tools like these programs are. You could, however, use a sample from either of these programs with the plugins I've listed if they were converted properly. Good luck! |
http://duc.digidesign.com/showflat.p...ev=#Post922747
www.klarityrecordingstudios.com |
Thnx for all the good advices, i got a feeling this willsolve my problems.
Kick Drum | dBHEAD | Tips & Tricks | 6 | 10-11-2011 12:01 PM |
Help with Kick Drum | torquemada | Tips & Tricks | 13 | 11-05-2006 07:20 AM |
2nd mic on Kick drum? | bigbubbaj | Tips & Tricks | 17 | 08-09-2004 05:10 AM |
60 Hz Kick drum | Brain Digger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-14-2004 10:37 AM |
Senheiser MD 421 or Shure Beta 52 for kick drum?r kick drum mic? | H-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 08-16-2001 07:07 AM |
