Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-14-2022, 06:41 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Default Re: Installing New Plugins DSP
Originally Posted by cp15 View Post
Hello!
So I am new to ProTools and Carbon as of a couple months ago.
Is it possible to install new plugins and have them run as DSP and not Native?
I only use a few of the DSP plugins that came w Carbon. Every new plugin I have installed has to run Native. Is there a way to install or configure so they run DSP?
Or if there is already a thread on this, please show me the way.
thanks!
Carbon is more or less designed to run AAX DSP plugins while the associated tracks are in DSP record mode so you can get near-zero latency in the monitoring and record path while all your other tracks are still running natively with native plugins, not run an entire session in DSP mode. You can do it but depending on the plugins and the size of the session you'll run out of DSP power quickly.
I have an HDX card I used for years (18 DSP Chips vs. 8 DSP in the Carbon) and I long ago abandoned AAX-DSP-based mix sessions. Native processing blows DSP systems away. The beauty of DSP in Carbon is near-zero latency for monitoring and recording. That's what the DSP in Carbon is intended for, tracking and monitoring during recording sessions. The only DSP plugins I use for mixing are UAD2 (Hardware-based system) offerings cause that's how they work and they don't make native plugins. Also, you can't use UAD2 DSP plugins for recording in Pro Tools, only mixing. You can only record with UAD2 plugins in their own branded audio interface (Apollo X series) within their Console structure alongside PT or inside their Apollo include DAW LUNA for close to near-zero latency recording. In other words, you'll be working in two environments, UA's Apollo Console and PT, whereas with Carbon everything is done in one environment, PT.
Here's a link to a string of videos from Avid about Carbon
https://www.youtube.com/watch?v=wYTm...YekJAY&index=1
Here's a video to better understand the beauty of near-zero latency recording in Carbon
https://www.youtube.com/watch?v=vy7xLgZRR4E&t=8s
I hope this helps.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Run plugins without installing??? jgiannis Pro Tools 10 11 04-13-2015 02:22 PM
installing a set of plugins, how do I do that? thinksamuel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-11-2007 06:59 AM
installing plugins infamous plague 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-03-2005 11:15 PM
installing plugins? romerom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-12-2004 01:07 PM
installing plugins...... woodbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-10-2004 09:06 AM
