Old 07-27-2010, 06:11 PM
Tex Tiles Tex Tiles is offline
Default Sound Replacer doesn't replace....
Hello,
I am a long time PT user and I upgraded my trusty G4 and 001 to a 8 core Mac Pro and 003 rack. Included in my purchase was the Sound Replace plug which I used to like quite a bit.
I have the authorization on my ilok and it loads just fine but does not process any audio and will not even preview. I have downloaded the plug several times thinking it was maybe corrupted or something, but everything seems fine, it just doesn't work......
Any suggestions greatly appreciated.
Thanks
Old 07-27-2010, 06:18 PM
necjamc necjamc is offline
Default Re: Sound Replacer doesn't replace....
Have you used the plug in updater. SR is on the list that gets updated for 8 (Or maybe even for 8.0.3. I was using it tonight and it works fine in 8.0.4.
Link Here.
Old 07-27-2010, 07:43 PM
I don't think that's it, but thanks for the thought. I just upgraded to 8.0.4 and it has a plugin updater included, and I checked the version and its soundreplacer version 8.0 which apparently is the right one. I can't get it to work either on my tower with 003 or laptop (macbook pro w/ mbox2). Weird.
Old 07-27-2010, 07:54 PM
dougied dougied is offline
I finally got it to work but you have to basically keep trying it. If it doesn't render the waveform, you need to undo Command-Z then do it again. It finally works after a few tries. It does suck that it isn't that great of a plug-in anymore. I need to find a better drum replacer plug-in.
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Old 07-27-2010, 09:49 PM
Nope, no worky.
It loads and looks fine but will not preview or render files. Very frustrating...
Old 07-28-2010, 03:19 AM
The Dougfather The Dougfather is offline
Is 'use in playlist' engaged?
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 07-28-2010, 10:01 AM
yup. engaged. wont even preview. but loads waveform into the window and calculates threshold etc. just doesn't do any of the replacing....
Old 07-28-2010, 01:57 PM
Figured it out....
I was loading SDII files as samples and their no longer supported. AIFF and waves seems to work fine.
Thanks for the replies.
Cheers
Sound Replacer HELP!!! Audio85 Pro Tools SE and Essential (Mac) 4 06-08-2010 11:23 PM
does syncronic replace sound replacer? tomcat Pro Tools TDM Systems (Mac) 6 07-06-2006 04:59 PM
Is there a drum replacer/sound replacer??? sethbrand General Discussion 2 03-08-2006 08:40 AM
my sound replacer makes the samples sound higher joeldavidlauver Pro Tools TDM Systems (Mac) 2 05-24-2005 07:59 AM
Sound Replacer Alters Sound of Sample. vze24x2x Pro Tools TDM Systems (Mac) 0 10-25-2003 07:10 PM
