Old 10-04-2016, 08:01 AM
shea shea is offline
Default Metre Panning Anomily
Hi Guys
How do I explain this. pro tools 12 win 8.1 digi 003
On a sterio track when I pan left or right it works fine but the metres remain the same as if it was centred . Is this normal or am I missing something
Thanks again
shea
Old 10-04-2016, 08:03 AM
Default Re: Metre Panning Anomily
What meter on what track... Sounds like a track is in pre-fader metering...
Old 10-04-2016, 11:54 AM
Thanks Darryl
No the track is not in pre-fader metering the track is a sterio track in the edit window and mix window. when I solo the track the trk meters go up the same on both sides panned fully left, but on the master channel the meters behave correctly only showing the left meter. I'm using digital vu meters but I tried the rest
Old 10-04-2016, 02:47 PM
dwaynedelario dwaynedelario is offline
I have always wondered this as well. Seems as though the track meters are pre-panner on audio tracks. Try it, pan one side of a stereo track all the way to the opposite side, and the meters on that track will not reflect the move regardless of pre or post fader metering.
MacOS 12.4 / Pro Tools Ultimate 2022.4
Old 10-05-2016, 06:02 AM
Thank you Dway
Is that normal behaviour or a bug?
Shea
Track Compression metre is in vanilla mix window boabyd23 Pro Tools 11 3 06-21-2013 02:27 PM
panning genoveva 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-29-2006 05:55 AM
panning bug? dkroger Pro Tools TDM Systems (Mac) 1 05-23-2005 08:45 AM
Panning Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-24-2003 07:10 AM
panning Ronnisi Pro Tools TDM Systems (Mac) 1 10-29-2001 02:00 PM
