Old 01-05-2006, 02:28 PM
BubbaHoTep BubbaHoTep is offline
Default how can I \"speed up\" without pitch change?
I just recorded several different individual speakers and put them on a FLASH presentation. The client asked if I could increase the speed on a couple of the individuals just a bit without significantly increasing the pitch. I was wondering if, and how, that would be possible using my Mbox with PTLE.
Old 01-05-2006, 02:37 PM
wolfskin wolfskin is offline
Default Re: how can I \"speed up\" without pitch change?
Bubba,
Try a plug-in like Serato Pitch & Time (or equivalent). It sounds like this is what you're looking for.
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2
AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM
www.wolfskinrecords.com
www.voodoopilot.com
Old 01-05-2006, 02:43 PM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Use the Time Compression Expansion audiosuite plugin that comes with PT (if you don't have a 3rd party plug-in like Serato Pitch & Time). It adjusts time with out effecting pitch. When used in moderation, it works pretty good. If you squeeze it too much you'll start to hear artifacts. If you hear artifacts, try sliding the sound/rythym slider closer to 'sound'.
Hope that helps.
Old 01-05-2006, 08:38 PM
The Weed's Avatar
The Weed The Weed is offline
If you hear artifacts, you can also try increasing the Crossfade from the default of 10 ms to 15 or 25 ms or more.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-05-2006, 09:42 PM
scar97 scar97 is offline
Use abbleton live if it cam bundled with your box. You can warp it and adjust the grain size. Use High quality Interpolation.
Digidesign pitch shift doesn't work very well
"It aint about the stuff you got..If it sounds right you're finished..Burn it!"
For all complaints click here
DAW
Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent
Old 01-07-2006, 12:11 PM
casperfun casperfun is offline
or the time compress & expansion cursor for PTLE 6.7 and later. For just a bit adjustments would be fine.
Help, Double speed WITH pitch change? brizpaul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-28-2011 08:05 PM
OT: Looking for app that will change speed with out changing pitch Overlord of the Undertone macOS 9 02-13-2011 11:56 PM
Change speed and pitch? likegluelikecrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-13-2004 09:37 AM
Tempo change without pitch change for audio layman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-16-2002 07:14 PM
CHANGE PITCH AND SPEED OF MIX [email protected] Tips & Tricks 5 11-24-2001 03:05 PM
