Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 02-23-2015, 06:23 PM
Josh Voyles's Avatar
Josh Voyles Josh Voyles is offline
Default Re: Waves Venue AAX DSP
Originally Posted by RyanJ View Post
I've similarly had multi rack have a show stopping failure. Well song stopping... So I stopped using non native solutions. Then again I've also crashed more DigiCo desks than I can count on two hands, and it's usually when trying to run Waves... But when it works, it's not too bad at all.
I'm actually just considering using multitrack on my computer via a MGB anyway. Some parameters I feel are nicer to adjust with a mouse anyway. Also, it it crashes I could just set up a macro that bypasses all inserts.
Old 02-23-2015, 06:34 PM
Originally Posted by Kristo Kotkas View Post
I do understand both companies, Waves wants the money of all engineers no matter what desk they use and Avid has created an ecosystem of their own DSP that is proven and easy to use.
It's up to you to decide if you like the idea of compact, tested system that saves your snapshots and show files into a single file to recall no matter what plugins you run or it's more important for you to have only that particular manufacturers plugins running and you don't mind carrying extra hardware around and you don't mind recalling/saving snapshots/show files on two systems and you don't need deep and easy Pro Tools integration.
It's a tough call.
I've always fantasized about setting up my own FOH. I'm running an SD9 right now and despite it's much smaller size, it's still kind of a drag to set it up and down every time.
Maybe some of the other plugs are worth a look. I just hate not being able to use my investment in Waves.
Old 02-24-2015, 09:38 AM
RyanJ's Avatar
RyanJ RyanJ is offline
What are the Waves plugins that you use the most? the indispensable ones?
Old 02-24-2015, 02:13 PM
In no particular order, these are the plugs I'd like to have in my toolkit.
L2 Ultramaximizer
C6
H-EQ
1176
Bass Rider
H-Delay
CLA-2A
API 2500
Ren EQ
Ren Vox
TransX
SSL Buss Comp
I would like to get inPhase.
-Josh
Old 02-24-2015, 02:56 PM
Kristo Kotkas Kristo Kotkas is offline
L2 Ultramaximizer
C6
H-EQ
1176
Bass Rider
H-Delay
CLA-2A
API 2500
Ren EQ
Ren Vox
TransX
SSL Buss Comp
-Josh
Fortunately many of these can be replaced, my favorite Waves plugin - RenBass in the other hand cannot, I really miss it :/
L2 style limiting - Pro Limiter/Avid, LM4000/McDSP, Oxford Limiter/Sonnox
Multiband comp/DynEQ - Mc2000/McDSP, AE400/McDSP, Pro Multiband/Avid
Classic compressors - Classic compressors bundle/Avid, 6030 Ultimate Compressor/McDSP
Transient tool - TransMod/Sonnox
Bus comp - Impact/Avid
.. and don't forget that All The Digital EQ's Are The Same :) :)
I know what you mean, I have Mercury and Platinum, both TDM. Mercury I use in the studio, so it's not completely wasted, but Platinum is just sitting... somewhere.
Old 02-24-2015, 06:16 PM
Thanks for the suggestions! I'll have a look at these.
Old 02-25-2015, 01:51 AM
It looks like some of those plugins aren't on Avid's list. Can you use any AAX DSP 64 plugin with the S3L system and have it be stable?
Old 02-25-2015, 04:02 AM
Witch ones you mean? To be honest I have not checked the Avid list... I know Sonnox and McDSP have S3L installers McDSP Downloads and Sonnox downloads Everything other than that should be Avid and should have proper installers available too.
Old 02-25-2015, 04:51 AM
Here's the listL https://www.avid.com/plugins
However, it looks like on McDSPs side, they have qualified all their plugins to work on the S3L.
"Take the power of McDSP plug-ins from the studio to the stage, and back again, with the release of Avid S3L support for all McDSP HD v5 plug-ins. McDSP has qualified all its AAX DSP plug-ins to operate on the S3L systems, and even added a few improvements to better support the S3 control surface. McDSP plug-ins like the new AE400 Active Equalizer, and bundles like Live Pack and even Everything Pack, now include support for this new modular, networked live sound system from Avid."
Old 02-25-2015, 05:12 AM
Don't worry about the list, I don't think there is anyone actually updating that list
Waves and Venue LanceK VENUE Live Sound Systems 4 07-03-2014 04:29 PM
Waves V9 and Venue KrisHeinold VENUE Live Sound Systems 2 08-09-2013 08:55 AM
Waves V9 is now Venue compatible digidesigner VENUE Live Sound Systems 5 07-25-2012 01:25 AM
Waves on venue!!! ThomasPMusic VENUE Live Sound Systems 1 01-13-2009 02:39 PM
Is Anybody Using The Waves SSL or API plugs on the Venue? dstagl VENUE Live Sound Systems 3 01-24-2008 02:48 PM
