Old 11-24-2013, 09:04 AM
lostinthehallway lostinthehallway is offline
Default SOLVED: DYLD shared region unnest,PT11.0.2 Crashing unexpectedly after plug-ins load
Hello everyone, and thanks in advance for any help or tips you may have.
I recently did a clean install of Mountain Lion (10.8.5), and PT 11.0.2 crashes unexpectedly after loading all plug-ins.
Console reads as follows:
11/24/13 5:51:58.929 PM Dock[219] no information back from LS about running process
11/24/13 5:52:10.000 PM kernel[0] Pro Tools (map: 0xffffff802d32c9f8) triggered DYLD shared region unnest for map: 0xffffff802d32c9f8, region 0x7fff8c200000->0x7fff8c400000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
11/24/13 5:52:12.641 PM com.apple.launchd.peruser.501[206] ([0x0-0x55055].com.avid.ProTools[458]) Exited with code: 5
11/24/13 5:52:12.740 PM Crash Reporter[466] Unknown class LengthLimitingTextView in Interface Builder file at path /Applications/Pro Tools.app/Contents/Frameworks/Crash Reporter.app/Contents/Resources/Breakpad.nib.
Right now I have only the stock plug-ins, and this was a fresh install of PT. It loads until the last plug-in, in this case Vari-Fi (before getting rid of all plugs it was Xpand!2), then crashes unexpectedly.
I've tried clearing the DYLD cache via OnyX, have tried booting in Safe mode (to clear the cache that way), and have also tried this terminal command:
sudo update_dyld_shared_cache -force
I tried all of these before and after re-installing Mountain Lion (not erase/install, just reinstall of OS)
Being that I'm not really a techie, I was hoping maybe someone has seen this before and that I won't need to wipe my system drive and reinstall everything all over again. Searching here and on google hasn't yielded much.
Thanks,
Chris
edit: Running on Mid 2010 MBP 7,1, 2.4ghz intel core 2 duo, 8gb 1067mhz ram
Old 11-24-2013, 01:48 PM
Default Re: DYLD shared region unnest, PT 11.0.2 Crashing unexpectedly after plug-ins load
As it turns out, the program Razer Synapse 2.0, for programming razer mouses was the culprit.
I figured it out after following some instructions I found on the Apple support forums. After running through some terminal commands and seeing Razer come up, I simply uninstalled it. Otherwise I would have had no idea.
So, if anyone else ever has this problem, and also has razer synapse, now you know
Chris
Mid 2010 Macbook Pro 7,1, 2.4ghz Intel Core 2 Duo, 8gb 1067mhz ram, Mountain Lion 10.8.5, Mbox 3 Pro,
Pro Tools 11.0.2
Mic Mod not showing up - PT10 and PT11 (solved) mesaone AAX Plug-ins 2 03-16-2014 12:24 AM
Help! 8.0.1 Won't Load!!! [SOLVED] DonM Pro Tools M-Powered (Win) 32 10-05-2010 02:57 AM
Pro Tools keeps crashing unexpectedly? Help! storm-01 Pro Tools TDM Systems (Mac) 7 02-14-2007 02:57 PM
PT "unexpectedly quits" whenever I load session... Amo Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-26-2005 04:14 AM
PROBLEMS since 6.4 update (unexpectedly crashing) charles_Mundelein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-27-2004 01:42 PM
