Old 02-26-2012, 12:16 PM
hankbalony hankbalony is offline
Question Eleven Rack user interface gone !
Hi there
I am quite a newbie I guess.
I am using (learning) Pro Tools 10 with Eleven Rack. Yesterday i had no problem getting the user interface for Eleven Rack on my computer screen, but today after upgrading PT to 10.0.1 I can't find the user interface for 11R ?
I have checked the windows menu, but no 11R there. I can record guitar....thats no problem, but the user interface is gone....
What am I doing wrong ?
Old 02-26-2012, 12:23 PM
thephil thephil is offline
Default
Buddy I had the same thing. Mine turned out to be a dodgy midi driver, once I removed that everything worked fine.
Does pro tools take ages to start up and lags in the setting up midi screen?
Old 02-26-2012, 05:02 PM
sorcerer27 sorcerer27 is offline
Default Re: Eleven Rack user interface gone !
Should have read this closer since you already stated it wasn't showing up in the Pro Tools Window menu list.
Old 02-26-2012, 05:30 PM
moff moff is offline
This is a commonly asked question, and there's even a sticky about it. During a Pro Tools upgrade, the certain files required used by the Expansion Pack get overwritten. Just run the first part of the expansion pack installer (NOT the firmware updater) to put the required files back into PT...
Old 02-26-2012, 06:25 PM
The Expansion Pack_73715 is the one you should be installing. When you're done re-installing follow it with a repair disk permissions, and finally reboot the system before trying it again.
Old 02-27-2012, 04:48 AM
Deny Deny is offline
Another thing, if all else fails check if 11R is selected as a MIDI device in ProTools configuration, if it isn't what you described is exactly what will happen.
Deny
My SoundClick Page
Old 02-27-2012, 05:59 AM
Hi there everybody
Thanx for all input and suggestions...
Today after i got home from work i started up pro tools and opened my latest project....and for some reason the Eleven Rack user interface did load !!
Also when I look in the windows menu, 11R is back in the bottom. (was gone yesterday)....spooky
Have not done any changes to PT, so I don¨t know what is going on...
so far so good.....
I have checked the midi input device and 11R is selected......but shouldn't 11R Rig setting and patch be displayed in the top menu of Pro Tools? I think i was there before....but not anymore.
Old 02-27-2012, 06:17 AM
You have to select the view for it to show up in the top menu, I think it's in the "Window" menu if I'm not mistaken.
Deny
My SoundClick Page
Old 02-27-2012, 07:12 AM
Thanx Deny
I right clicked on the top menu and i could choose Eleven rack... It wasn´t there yesterday....
Thanx a million...
Old 02-27-2012, 09:30 AM
When it wasn't in the Window pulldown a reboot of both system and 11R for these types of things is always a good idea to try. Glad you got it squared away.
New Eleven Rack user DMannDann Eleven Rack 7 01-11-2013 09:31 PM
New Eleven rack user mlyemance Eleven Rack 6 09-22-2011 08:43 AM
New Eleven Rack user here Big_Daddy Eleven Rack 7 12-27-2010 06:39 AM
