If you were mixing 3 songs this week,top 3 plugins?
I know this is subjective,but other than the standard hd and plugin pack I don't have any great comps or eq's. I'm mixing inside HD so if you had 4 days to mix 3 songs, which plugins do you consider must have? For now I'll keep it to $1500 or so, but one more thing, where do you buy them? From digi, or direct, or...which is the best deal?
Thanks for your help, daniel |
Re: If you were mixing 3 songs this week,top 3 plugins?
My must have -
McDSP Filter Bank Compressor Bank Analog Channel MC2000 and . . . DaD Tape and Valve. Check with dealers and on the web. Most are priced within $10-$20 bucks of each other. Never hurts to check the used market also (legit used market - get auth disks and reg transfers)
2019 Mac Pro 7,1 192 GB RAM Catalina OS 10.15.7 PT Ultimate, or whatever 2022.6 is called now HDX 2 w MTRX, Dadman 9.1.4 Dolby Atmos over Dante to external RMU |
Sony EQ with GML option
Sony Dynamics Time adjuster [img]images/icons/grin.gif[/img] |
McDSP FilterBank
McDSP CompressorBank Waves L2 Waves RenVerb Reverb One
macmandigital.com |
Altiverb
Filterbank Compressorbank
Dual 2.3 GHz PowerPC G5 2.5GB RAM OS 10.4.6 HD 2 Accel PT 7.1cs9 192 I/O |
L1 Limiter
vocAlign project compressor bank channel strip |
Only 3 plugs?
For EQ/Comp the question is if you have enough DSP Power. If Yes: SonyEQ SonyComp If no: Filterbank Compressorbank for the third Plugin it depens what you need. Reverb: Altiverb or Reverb one Chorus: Wave Mechanics Soundblenders ? daniel www.ideeundklang.com |
If you dont have any outboard gear youll need at least the following:
For EQ: Filterbank For compression: Compressorbank Reverb: R-ONE Chorus-Delay: WaveMechanics Master Fader: L2 If you have a PT|HD3 "maybe" SonyOxfords, they are like 3.5 expensive than McDSP's but I dont think they perform 3.5 times better than McDSP's... its all hype....
Camilo Orozco Like us on www.facebook.com/artedigitalestudio www.estudiodegrabacion.com.mx |
thanks daniel |
Thanks guys for all of the helpful responses!
I have HD1 so I do have to watch the resources. I will be using external fx,a lexi 81,an mpx-1, an eventide eclipse and some analog stuff. I kinda figured it was between the mcdsp and sonys. I was also wondering about the fairchild and the inflator, maybe not as much utility value in those? Also waves L2, is that pretty much THE ONE you guys use on the master fader? Will the Mcdsp comp bank do 2 buss too? I haven't seen the sony and mcdsp stuff at many online places, I assume mostly proaudio dealers would have them? thanks again daniel |
vocal editing and mixing to do cover songs | livepast00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 12-29-2010 03:44 AM |
Mixing Multiple Songs In One Session | Keniko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-20-2007 04:52 PM |
mixing 5 songs with the same eq/compression | mr razor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-04-2006 04:00 PM |
Mixing 10 songs in 10 hours | wikked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 01-19-2005 06:34 AM |
mixing different songs on the same session | andre tchmil | Tips & Tricks | 8 | 03-18-2002 06:18 PM |
