Protools 8 projects in 9: playback issue..
Hi 2 all !
Situation: Protools HD 9.03 on 10.6.7 MacPro, early 2008, with 8 gigs ram. In PT 9 I open a project that was made in protools HD 8.05. Now, when i hit spacebar (play) , it takes about 3 seconds for protools to actually go in play. I have this problem with all my old protools 8 projects. I then changed buffer settings in the playback engine, but no succes. i have delay compensation off. I do use the same audio HD as with protools HD 8. This is really annoying, anyone has same experience ? Best, Rob. |
Re: Protools 8 projects in 9: playback issue..
Ok, i will, thank you for the tip !
Rob. |
Can't playback most projects suddenly - Spiking like crazy | DUCHUNTER | Pro Tools TDM Systems (Mac) | 6 | 04-02-2013 10:23 PM |
Eleven Rack playback issue in ProTools LE 8 | Tony-N | Eleven Rack | 19 | 04-27-2012 03:23 AM |
ProTools 9.0.3 Loop-Playback Selection issue | hpfmn | macOS | 3 | 06-22-2011 03:23 AM |
Sending protools projects to other protools users online | kdtufan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2008 07:18 PM |
LOADING UP NON PROTOOLS PROJECTS... | DLinares | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-17-2006 05:29 PM |
