Old 06-28-2017, 07:43 PM
SBP SBP is offline
Default Re: BUG: Multiple output assignment key combo broken…
Originally Posted by john1192 View Post
may i ask what computer you have that this is working on ?? might be one of the differences .. this cannot be a preference !!!
MacMini 2.5Ghz I7 2x2. +OMNI
Tommrow I'm going through 12.8.0 in a bit more detail today has just been about install and quick test... so far looking pretty good.
Cheers
Bruno
Old 06-28-2017, 07:50 PM
john1192 john1192 is offline
Cheers
Bruno
and an HDNative Thunderbolt Box to the Omni ?? right !!!
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-28-2017, 07:52 PM
SBP SBP is offline
Yep
strangepumpkin strangepumpkin is offline
Tested this on my Macbook Pro Mid 2012 OS X 10.12.5, PT 12.8 and it works fine.
Kyle Whittaker
www.strangepumpkin.ca
Mac Pro (2013)
3.5GHz 6-Core Intel Xeon E5
32 GB Memory
OS X 10.12.6
PT 2018.1
Old 06-28-2017, 07:57 PM
now this is getting weird that it works for you too
.. i can UnAssign any of these multiple output assignments that were made in 12.7.1 just fine .. but i cannot assign in 12.8 to more than one Selected Track ..
what are we missing here !!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
  #16
Old 06-28-2017, 08:05 PM
i just tried this on a 2nd computer .. macbook pro and Still i cannot get it to work .. using 12.8 ..
12.7.1 is fine ..
man, you guys are not screwing with us are you !!! this makes no sense ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
  #17
Old 06-28-2017, 08:12 PM
12.7.1 is fine ..
Just ran a test and was able to re-create the bug. Originally, I was testing using a session that was created on 12.7.1 and it worked fine. Then I tried again using a template (template was made with an earlier version of PT) and still no issues. But once I created a brand new session from scratch, the bug appeared.
EDIT: And, since I've created a new blank session, even the sessions created on 12.7.1 have the bug. It's weird, it's like opening a blank session switched something in Pro Tools.
Kyle Whittaker
Mac Pro (2013)
32 GB Memory
OS X 10.12.6
PT 2018.1
  #18
Old 06-28-2017, 08:43 PM
whew ... finally ... i can sleep tonight !!! thx for reporting back ... "It's weird, it's like opening a blank session switched something in Pro Tools" yes, agreed ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
  #19
Old 06-28-2017, 08:46 PM
I think it was a crash that did it. When I was initially testing between previously created sessions, I thought I should try a blank, when I made one, PT crashed. After that, the bug was present.
Kyle Whittaker
Mac Pro (2013)
32 GB Memory
OS X 10.12.6
PT 2018.1
  #20
Old 06-29-2017, 06:46 AM
anyone here have a PC that they can test this on ???
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
PT quits every time I change an output assignment fm_xtk macOS 4 05-18-2017 05:52 AM
Artist Mix - Eucon 3.0 introduces a new output/bus assignment scheme in Pro tools 11 Emcha_audio Artist Series 1 09-24-2013 01:39 AM
Output assignment bug pmklein Pro Tools M-Powered (Win) 0 07-01-2009 05:00 PM
Structure output assignment problems Extreme Mixing Virtual Instruments 0 11-19-2007 02:19 PM
Multiple Track Assignment to Auxes in LE Girl6 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-27-2006 06:18 AM
