Old 03-01-2012, 10:43 AM
nstu nstu is offline
Default SSD drive (system) or 8gb ram more?
Hi guys,
i'm on a mac pro (2008 / 3,1), lion and 6 gb ram.
i want to add more 8gb ram to get up to 14gb for a faster system (and some more power for vi instruments.)
but then i saw some threads about ssd drive as a system drive where the system worked much faster. better start up, faster session loading...
the price for 120 gb ssd or 8 gb ram it's the same.
what would you go for at first?
Old 03-01-2012, 12:24 PM
Redbeard Redbeard is offline
Default Re: SSD drive (system) or 8gb ram more?
With PT10 able to load the whole mix into RAM, I'd save the money and get the RAM. It really speeds things up and no need for disk access, even really fast disk access.
Old 03-01-2012, 12:48 PM
serio serio is offline
Just to clarify, that's only with the HD software or regular PT10 w/CPTK.
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
Old 03-01-2012, 02:52 PM
epiphone epiphone is offline
I think you are using an imac. I bought 16 g of ram at OWC for $100.00 recently much cheaper than an ssd.
Currently Ptx only accesses 3 g as it is 32 bit. The next version of pt is likely to be 64 bit and supposed to load your whole session into ram.
Why not buy the ram and save the money for the 64 bit version of PTs ?
Epiphone
Old 03-01-2012, 11:21 PM
barakka barakka is offline
With Pro Tools being a 32 bit application it can only access 3Gb RAM... BUT if you have Pro Tools HD or CPTK then you can use Ram Cache which is a 64Bit application which runs externally to Pro Tools and you can assign any Ram above the 3Gb needed for Pro Tools to cache the session.
Ram Cache makes the session being used super responsive.
An SSD boot drive will speed up boot and loading times of everything, my MBP boots in around 12 secs and once logged in Pro Tools loads in around 15 secs.
Hope this helps...
Originally Posted by The Mock Turtle
“Reeling and Writhing, of course, to begin with, and then the different branches of arithmetic -- Ambition, Distraction, Uglification, and Derision."
Old 03-02-2012, 01:56 AM
Default
Originally Posted by epiphone View Post
Epiphone
have a mac pro 2008. the best price for 8gb are about 180 euro in germany. i am still on pt10 without disk cache. i think a faster system is now better for me. so i will buy an ssd.
Old 03-02-2012, 04:52 AM
Let us know how it works out !
Old 03-02-2012, 04:57 AM
Default
in will do that. now i just have to decide which ssd. i think the intel 320 with 120 gb is a safe choice and in a good price range.
Old 03-02-2012, 05:45 AM
dougied dougied is offline
http://www.macsales.com has some awesome SSD drives. They are super fast and affordable.
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Old 03-09-2012, 02:07 PM
At first, thanks dougied for the advice of macsales!
i ordered (through amazon, because it was faster and same price range) the OWC Electra 120 GB 3G.
i did a clone with carbon copy cloner of my old hdd system drive and just a half hour later my ssd rocks my last pt-session in my mac pro.
no problems so far and its great. boot up feels more than two times faster. apps opining faster and session loading its much better too. the best thing is plug in load. before the ssd the audio stops for a moment when i insert heavy plugs when i have a bigger session. but know the plugs open up faster an without a break. the whole system "feels" better.
now i have the problem, that i need a second ssd for my macbook pro (2011). It has even more ram (8gb instead of 6 as my mac pro) but i feels a bit lame
If anybody is interested, i wrote a little review of my new drive setup at gearslutz (http://www.gearslutz.com/board/music...le-review.html)
No Audio, But Just Samples. System Drive Or Seperate Drive. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-10-2010 03:47 PM
System Drive and Audio Drive Question. philip888 Pro Tools M-Powered (Win) 2 06-03-2009 11:30 PM
Audio drive plus system drive, where Structure? Blustar Virtual Instruments 3 09-17-2008 04:01 PM
scsi ultra160 disk for system drive and audio drive jazzle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-23-2001 06:54 AM
anyone using the system drive and storage audio drive in the same SCSI chain? riorecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-15-2000 11:09 PM
