Old 01-05-2023, 07:26 AM
taylor4814 taylor4814 is offline
Default Laptop Soundcard Sample Rate Greyed-Out, Can't Change?
Pro Tools Studio 2022.12
Dell Inspiron laptop - 12th Gen Intel® Core™ i7-1255U
Audio Controller: Cirrus CS42L42 (Cirrus Logic High Definition Audio sound card)
Driver: Cirrus-Logic-High-Definition-Audio-Driver_78XG8_WIN_10.0.7.39_A01
Windows 11 Home
Version 22H2
OS build 22621.963
Feature Experience Pack 1000.22638.1000.0
I am hoping to successfully run Pro Tools on this laptop, and resolve this issue... any suggestions welcome...
The sound card sample rate dropdown menu is greyed out, and can't be changed... (it's set to 16 bit, 48000 Hz)
Pro Tools can select the Windows audio device, and can play a 16/48 session through the onboard speakers — but no other sample rates are available.
I've tried ASIO4ALL, and Pro Tools can select it, and other sample rates are available, but so far it's unable to access onboard speakers...
I've tried driver re-installs and most settings changes I can think of, with no luck yet...
Old 01-05-2023, 07:30 AM
junkgear's Avatar
junkgear junkgear is online now
Default Re: Laptop Soundcard Sample Rate Greyed-Out, Can't Change?
Pro Tools and Windows audio do not play well together. Your laptop sound device is being controlled by Windows, so whatever sample rate it is set to is what PT will be forced to use.
If you plan on doing any serious work in PT, it is strongly recommended to get an ASIO compliant external audio device. This way, the device will be exclusive to Pro Tools and you can freely set the sample rate as you wish.
Will
System Details
Old 01-05-2023, 07:39 AM
Thanks- yes, typically that is how I have my main machines set up. On this laptop, I'm trying to see if a change is possible, as I've seen it's possible in some cases...
Old 01-05-2023, 08:10 AM
sw rec sw rec is offline
Buy an interface. And make sure Windows isn’t using it as the default sound device.
Old 01-05-2023, 08:23 AM
Yes, that is my typical workflow...
Old 01-05-2023, 08:27 AM
< ✅ Solved > I reset ASIO4ALL to defaults, and that seems to have solved my issue, at least insofar as ASIO4ALL goes...
Sample Rate Greyed out in PT12? weezerboy Pro Tools 12 3 12-31-2015 10:53 AM
Sample rate greyed out? sw rec Pro Tools 11 5 11-05-2013 06:07 PM
Sample rate greyed out and stuck on 44.1 kHz pzykt macOS 1 06-01-2013 04:30 AM
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
how to change sample rate?? remains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-28-2002 04:38 PM
