  #131
Old 06-25-2021, 05:41 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
Default Re: Pro Tools 2021.6
Don't know whether to post this here or on the Pro Tools Carbon thread, but;
Odd behavior was noticed with my Carbon after updating the firmware of Carbon.
None of my meters on the unit were functioning. I rebooted a couple of times and still not working. I switched from in to out meters, still nothing. muted and dimmed, no joy.
Everything else seemed to be working fine except for the meters.
Finally, with no headphones connected, I pushed the headphone button, and now all meters and everything seem to be just fine.
I know, by virtue of having a MSME, that sometimes things get confused digitally. But, I thought that @Kyle Splittgerber may wish to know, and to alert any other Carbon user.
Thanks
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
  #132
Old 06-25-2021, 05:49 AM
Garnoch Garnoch is offline
Originally Posted by glogulus2003 View Post
Hit return after each line.
Thank you. Tried this one out but it didn't work for me. The message I got was, kmutils: command not found
Here is what I did in Terminal while in Recovery Mode...
mount -uw "/Volumes/Macintosh HD"
(Return)
kmutils trigger-panic-medic --volume-root "/Volumes/Macintosh HD"
(Return)
So after reading your link, I tried kmutil instead...
(Return)
kmutil trigger-panic-medic --volume-root "/Volumes/Macintosh HD"
It appeared to work, but then after reboot, I simply got one single pop up telling me "Panic Medic Boot" and that all third party kernel extension were disabled and would need to be approved "as they are used". I went to Security in System Prefs and there was no list like there was for you. There was nothing. I couldn't get it to work. I rebooted again and the "Panic Medic Boot" message did not pop up and I appear back to where I was.
Then I tried to reinstall the HD Driver again and this time I got multiple popups about extensions needing to be approved like you did. I went to System Pref/Security and had an Option button to check off th extensions to approve including Avid. After restarting from the HD Driver install, everything worked.
THANK YOU
I do have a new issue though since using the Terminal. Three times now my Mac doesn't want to restart. After waiting a bit (while it looks fully shut down), I have to hold the power button as if I'm forcing a shut down, then I can start it up fine.
  #133
Old 06-25-2021, 05:50 AM
K Roche's Avatar
K Roche K Roche is offline
Thanks
Thanks for the heads up. (curious what is MSME) ?
System :
Enjoy the Journey
.... Kev...
  #134
Old 06-25-2021, 06:30 AM
BCnSTL's Avatar
BCnSTL BCnSTL is online now
Default Re: Protools 2021.6
M1 Mac user here. I went back to 2020.3.1
I’m getting beach balls and UI glitches every 10-20 seconds with 2020.6 - on every session I’ve loaded.
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD.
2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD.
PT 2024.3 Native
Life is like an Analogy.
  #135
Old 06-25-2021, 06:37 AM
daeron80 daeron80 is offline
Some of y'all don't read Pro Tools Expert, and it shows.
David J. Finnamore
  #136
Old 06-25-2021, 07:13 AM
Cowboy Bob's Avatar
Hey Kev, MSME = Master of Science, Mechanical Engineering.
For years my day gig was as a mechanical engineer. I worked for a defense contractor for several years, a heavy equipment manufacturer, and a company that makes electrical control, distribution and sensor products.
Bob
  #137
Old 06-25-2021, 07:41 AM
briaboy briaboy is offline
I like the new box that comes up suggesting exactly which plugin has caused PT to crash!
iMac (2020: 3.8 GHz 8-Core Intel Core i7, 32GB), OSX 14.1 (Sonoma), Pro Tools 2024, UAD Apollo 8, UAD-2 Quad Satellite DSP Accelerator, 2 x Lacie Thunderbolt SSD (250GB), Seagate Backup Plus Drive (4TB).
  #138
Old 06-25-2021, 08:16 AM
RobbaDobba RobbaDobba is offline
I got burned by jumping on 2021.3 and 2021.3.1 early. Won’t be doing that again. I’m gonna stick with 2020.12.1 a bit longer.
Would you early adopters be dears and continue to report on Pro Tools Standard on Mojave 10.14.6 for me? Don’t care about video. Thanks bunches!
One good thing about music: when it hits, you feel no pain. --Bob Marley
Rig: MacBook Pro (15,1) 6-Core i7 2.6GHz / 32GB RAM / OS 13.5.2 / PT 2023.9 / Waves Horizon v14 / iZotope Music Production Suite 4.1 / Focusrite Clarett 4pre USB / Apple SSD AP1024M 1 TB (System), Samsung T5 SSD 1 TB (Audio) / Cal-Digit TS3 Plus TB3 Dock / Genelec 1030A Monitors
  #139
Old 06-25-2021, 08:18 AM
SaschaP SaschaP is offline
Question for all:
If you update to 2021.6 and it requires that your HD Native / HDX cards update to the current firmware version... can you still use older versions of PT with the new firmware? Thanks!
  #140
Old 06-25-2021, 08:24 AM
glogulus2003 glogulus2003 is offline
Ahh, sorry about that! I fixed my earlier post. Thanks for catching it!
Have you tried to let it sit and see if it eventually restarts? That's about all I can recommend.
Recommended iMac Specs for Pro Tools 2021.3 (Pro Tools STANDARD) BigSur Compatibility Spoil the Child macOS 19 04-05-2021 05:35 PM
Pro Tools First 2021.3 is out Netmania Pro Tools | Intro Discussion 2 04-02-2021 01:26 PM
