Old 02-19-2012, 12:56 PM
Empireofthesun Empireofthesun is offline
Default Session Problems playing
I got a session today for mixing..Im mixing thru my Saffire 56 and then into my Sonifex for monitoring..
When opening the session I got "Pro ToolsHD DSP,120 Voices
This playback is not avaliabe with current hardware.Would you like to continue and use the current playback engine"Saffire"
I click ok open session and it wont playback
Ive chanaged all the outputs to 1-2 outputs with regard to my Saffire and defaulted the I/O section and still wont playback
Changed the sample rate to 48 as it was recorded in that and then it wont budge
Any ideas?
Old 02-19-2012, 08:45 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Session Problems playing
How many tracks are in the session?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 02-20-2012, 12:08 AM
BillDog793 BillDog793 is offline
You could create a new session and import the session data, see if that gets it going.
Old 02-20-2012, 05:11 AM
There is about 20 tracks..so not too many
tried importing into a new session and getting the same problem
Old 02-20-2012, 11:44 AM
So it sounds like the session itself actually opens, and the actual problem is playback. If you consolidate the audio tracks to the start of the session, you could create a new session and just import the audio instead of the session data. Doesn't really fix the problem, but at least should let you start getting your mix on.
[IMG] code is Off
How to preview audio while session is playing? Dan-Jay Windows 3 06-22-2012 06:50 AM
No Sound When Playing Session Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-22-2005 08:24 PM
Session not playing some tracks Ecarter Pro Tools TDM Systems (Mac) 3 07-10-2004 09:38 PM
Playing session over internet fxbuilder Pro Tools TDM Systems (Mac) 1 08-23-2002 06:09 PM
Playing a TDM session in a Digi 001 / LE johnnyonthespot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 05-22-2002 03:20 PM
