Punch In Record w/ footswitch on the Mbox Studio
As far as the Mbox Studio interface, am I able to record punch in and out with the footswitch jack on this device like the Mbox 3 pro? Thanks everybody!
Tony |
Re: Punch In Record w/ footswitch on the Mbox Studio
Sadly, this detail is missing(and I have been complaining for months). You have 2 solutions for now:
1-add a Presonus Faderport to your setup(it has a foot switch jack for quick-punch), which actually brings a lot more than you might think, especially if you pair that with neyrinck's V-Control Pro software(must get the Faderport V2 for this). 2-learn how to do auto-punch. The quick lesson is to enable a bar pre-roll, place the cursor exactly where you want to punch in, enter Record(playback will start 2 bars early and put you in Record at the spot you selected. Also, don't foget you can use Loop Record and(in Preferences) set PT to create a new playlist with each pass
Wow.... this is insane.... This should be par for the course to add that feature... Are you saying to add the fader port into the mbox or just use the fader port?
Mbox 3 pro supports both quick punch and Midi punch correct? Do you think there may be a work around on the midi punch on the Mbox Studio to still make it possible at this time? Thank you for your support!! Tony |
@ albee1952 I see what your saying about the fader port.... its a control surface for DAWs. I still wonder if the midi assignments for the footswitch on the Mbox studio can be used for punch ( a control midi message?)... You've obviously have researched this topic... We may have to wait for the firmware update for the Mbox studio to address this( if they even will?)
Thank you again!! |
Avid keeps saying its coming, but won't say when....
M-Audio ProjectMix i/o footswitch punch/record instead of play/stop? | Kanayama Sound | Third Party Interfaces | 1 | 09-03-2020 09:52 AM |
Mapping a footswitch to punch in and out? | Doc H | FireWire & USB Audio Interfaces (Win) | 1 | 04-24-2019 01:18 PM |
Footswitch for Punch In? | Moontan NYC | Third Party Interfaces | 4 | 07-13-2014 09:45 PM |
Punch in/out footswitch | cjs102460 | ProControl, Control|24, Command|8 | 4 | 11-14-2010 12:38 PM |
Can you punch in without a footswitch? digi 002? | fafaflowley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-12-2005 09:20 AM |
