Re: Mbox studio latency
I'm really interested in upgrading my Digi003 BLA Mod for the better convertors, but I really want to maintain that 32buffer setting. Thank you as always.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
FWIW RME UFX II or UFX III (since I use MADI) would be my first choices.
If you have more time and can create a test session with just a mono audio track and add a hardware insert on that track (between matching I/O on the Mbox). Then enable ADC and look at what latency is being shown in the ADC panel for that track. That should be identical to the reported RTL (but not actual measured RTL) you posted earlier... unless Pro Tools is doing something funky here. I'm surprised by the difference in reported and actual RTL. |
And 448 is not one of any of the reported or actual measurements... OK so then next question is does that ADC value actually correctly time align the hardware insert? If I can indulge you further... use a straight through cable (on analog IO not on ADAT or S/PDIF IO). Record a click to an audio track, place an insert on it and then record that track output to another audio track... with ADC enabled both tracks should perfectly align, but I am suspecting here they might not. If not what is the offset in #samples measured between waveforms?
#16
#17
Oh Avid, what have you done? How do you screw up basic latency stuff so badly?
Now I have to wonder if this box even gets basic input timing correct. This is all pretty disappointing and already enough reason I would avoid the Mbox Studio, and then there is the eight output limit. |
#18
Using Core Audio
Mix Stage 1 PT HDX Ultimate 2022.12 D-Control HD I/O Hackintosh i9 12900K 32 Gb RAM OSX 12.6.7 Mix Stage 2 PT HDX2 Ultimate 2023.6 S6 MTRX I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 Mix Stage 3 PT HDX Ultimate 2023.6 D-Command HD I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 ADR PT MBox Studio Ultimate 2023 Mac Mini M1 8 Gb RAM OSX 13.4.1 Edit 1 PT HDN PCIe 2023.6 96 I/O Intel i7 6700K 32 Gb RAM.OS Windows 10 Estúdio JLS Facilidades Sonoras São Paulo - Brazil |
#19
Interesting, thanks for posting Core Audio.
#20
Yeah that's why I'm parked on the Digi 003. It's crucial to have the 32buffer for tracking bands live, since that's my FORTE.
Mbox studio lowest latency | frazzz | MBOX Studio | 8 | 10-25-2023 01:04 PM |
Desktop PCs w/ Win11 for Pro Tools Studio/MBOX Studio | forumuseraccount1234 | Pro Tools | 0 | 04-01-2023 05:18 PM |
Low Latency Monitoring in Studio | seanmccoy | Pro Tools | 17 | 08-03-2022 11:35 PM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Help with UA Studio Pak and 002 Latency | danny4cm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-18-2004 04:55 PM |
