midi/virtual instruments problem
I know I'm missing something obvious but could someone be kind enough to point it out to me?
Everything is set up right. Triton Extreme midied into the 002 and then into my pc. When I call up sample tank in the instrument track and hold down a triton key, on some songs it plays the sample tank but on others, it won't. I have compared the "wills" and the "won'ts" over and over but for the life of me, can't figure it out. Thanks much for the help. |
Re: midi/virtual instruments problem
What version of Sampletank? If it hasn't been updated, you will need to select a valid hardware audio input on whatever track you are inserting on.
Thanks for the reply.
It's Sample Tank 2 (the one that comes free with the 002 bundle). Do I need to update it? Can you explain a little more about "you will need to select a valid hardware audio input"? Again, thank you very much for your time. |
When you insert the plugin on an instrument track, select a hardware input (i.e. Mic 1&2) as the audio input for that track. This only applies to older plugins that aren't 7.x compliant. (hence the suggestion to update)
spkguitar. . . thanks so much!
Problem with multichannel virtual instruments on Pro Tools | Fredfkg | Pro Tools 10 | 3 | 03-20-2012 12:17 PM |
Playing Virtual Instruments Problem | jaxsun23 | Virtual Instruments | 0 | 11-04-2009 12:10 PM |
Protools 8 and Virtual Instruments Problem | Tom Polce | Pro Tools TDM Systems (Mac) | 2 | 03-24-2009 01:47 PM |
Problem with Trial virtual instruments | DR COMP | Virtual Instruments | 2 | 10-27-2008 03:32 PM |
Virtual Instruments/Midi | MusicalWonder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-16-2006 06:40 PM |
