Re: So how is it ?
Chris Lambrechts Applications Specialist- Live Sound |
Re: So how is it ?
Aslo, are there any Houses of Worship using VENUE? |
Re: So how is it ?
What is the setup for stage side monitor mixing? A diffenrent analog console with outboard guear and a split snake, or a second Venue linked to the stage rack? JC |
Re: So how is it ?
As far as I know, I am the only one to be using the Venue as a monitor mix console. I have fully tapped the resources of this amazing piece of hardware/software mixing tools. If you are interested in discussing the why's and how's lay it on me.
Re: So how is it ?
doing monitors for NIN?
#16
Re: So how is it ?
To further ensure reliability the D-Show software is an entirely purpose-built application, written from scratch - it is not a variant of Pro Tools. All audio processing takes place on the D-Show Mix Engine cards, so the OS itself does little more than serve graphics and control data. Taking things a step further, the D-Show Mix Engine cards have enough intelligence to take over direct control of channel faders, channel mutes and fader banking should the computer ever fail or need to be re-started, so you never lose control of the mix and audio continues passing with all processing (inluding plug-ins) intact. Quote:
Sheldon |
#17
Re: So how is it ?
So will XPe be available for other functions (ie other audio work)? It sounds like a great idea to me!
#18
Re: So how is it ?
mixmic, as you have said you are willing to share some experiences with this system and I would be very happy if you could give me some input on some guestions that I have. So if you are working with this great american industrial band then as I think I have seen they are most probably using inears and wedges combined. So is the plug-in latency giving you any headaches? I have an analog console/mix++++ system @ my studio and when I have tried to use eg. ren. comp. inserted for vocal monitoring the added latency has been way too big. In live situations I have used Yamaha digital consoles for live in-ear mixes and they have been OK to use with built in eq`s and comp`s switched on with no really disturbing side effects. Also can you access stuff fast enough for monitor work? I mean is it suitable for every-day festival type work with bands changing fast or is it more(only) suitable for touring artists that can have like week or even more to fine-tune everything to their liking? thanks, Kristo |
#19
Re: So how is it ?
As with any new piece of gear, there is a bit of a ramp up to get my head around the workings. Once being able to put my hands in the right place at the right time and maintain job security, the Venue has proved to be an artistic enhancement my mix environment. With proper set up, I don't see a problem using this on a mutiple band set up such as a festival or tour. If one we to walk up and mix a band for the first time on the fly, with a qualified engineer assisting, a competent mixer should not have a problem getting up and running. The first time may be a bit hairy but do-able. After that your going to want one too.
The plug-in must be pre-assigned and can not be added on the fly because of signal interruption. You can get futher details on that without me going into it but also should not be a problem with some simple planning. Not having to have racks of outbaord gear is pretty exciting and being able to try out different plug-ins without having to call you audio contactor to ship something out is an extremly powerful feature. This is the future of audio, now. |
#20
Re: So how is it ?
In pre-production w/NIN. Been using Venue for 6 weeks, feeling really comfortable with the desk. Made some recording using the analogue outs to PT and that has worked out well. In-ears, wedges, loads of things going on with no drawbacks. Nice small footprint, two people can lift desk and side car if you've eaten meat in the last year. You will love the way this sounds. The people at Digi are listening to the engineers using this now and will make improvements along the way but only after major scrutiny. Rock solid as it stands right now.
