FireWire Solo driver upgrade crashes PT 7.4
'Nothin but problems ever since installing new M-Audio driver (FW_V32_5.10.00.5053.exe).
I'm using Pro-Tools 7.4 on a Windows XP Pro SP 2 with all other equip meeting specs. Now, when I try to launch Pro-Tools, I get a total system crash. I even tried re-installing the old M-audio Firewire solo drivers that came with the package on a CD...same result...total system failure. Does the new driver change the firmware in the FireWire unit? Anyway, hoping for any insight or suggestions someone might have. Thanks! Dave in Vegas |
Re: FireWire Solo driver upgrade crashes PT 7.4
OK....Great! So no Digidesign guys want to respond.
I've been on the phone to M-Audio all morning. We've run all the diagnostics, un-installed, re-installed, and have shown to their satisfaction that the M-Audio FireWire Solo unit is operating fine. They're sending me over to DigiDesign to talk to tech support about Pro-Tools. How much you wanna bet they'll send me back to M-Audio once they hear the M-Audio drivers are the culprit? Not only that, but the Pro-Tools support is not free. These software/hardware interface problems never get resolved, 'cause each company (even tho closely related) keeps blaming the OTHER for the problem. How 'bout a tech support conference call between Pro-Tools, M-Audio and ME?! Hoping for your response. My pro-tools 7.3 is still crashing my computer when I launch the program. I now have the M-Audio FireWire Solo drivers FW_WDM_5.10.00.5036v2 installed. But the newest drivers have changed the firmware in my Solo unit... and I think that's the problem, but no one wants to admit it. need your help! Dave Courvoisier in Las Vegas |
I don't know much about M-audio drivers, but when you boot up Pro tools, watch the screen as it's loading the plugins and DAE and see at what point it crashes. The plugins go in alphabetical order. Maybe there's a plugin that is the culprit and removing that will solve the problem. Alternatively put all of your plugins in the unused plugins folder and try booting Pro Tools. at least then you'll be able to eliminate plugins from the equation. Also in your first post you say that your using PT7.4 and in the second 7.3? I had to download a patch from microsoft before 7.4 would work on my PC after going up from 7.3. http://shup.com/Shup/10707/WindowsXP...37_x86_ENU.zip JazzyJ
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
Thanks, JazzyJ....
I've been trying both versions of PT to see which might work with the M-Audio drivers. Neither does. As for your other question: Most times it just crashes right away...immediately. On the one or two occasions when it got part-way through the loading of plug-ins, there seemed to be no pattern. Thanks for the shout.... 'still workin on it! Dave in Vegas |
You should start with the steps in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting thread and post specific info on your system per the info on that thread if you're unable to resolve the problem.
You may want to look at the Help us help you thread as well. |
Thankyou DigiDesign support. I DO appreciate your response.... lots of links... lots of ideas...
But before I start jumping through a ton of diversionary troubleshooting hoops... here's the bottom line: This very computer I'm now having trouble with worked JUST FINE with the hardware/software configuration for months. The ONLY....ONLY variable that precipitated this spate of trouble was installing the new drivers for the M-audio unit. Wouldn't it make common sense to trouble-shoot possible issues with THAT as the logical first step? I KNOW this computer works with Pro-Tools 7.4cs and the M-Audio FireWire Solo. So all this configuration stuff, and minimum equipment requirements -- while common to your protocol as a troubleshooter -- is a waste of time for me...with all due respect. What I need is the absolutely impossible scenario of getting an M-Audio tech support guy and a Pro-Tools tech support guy together on 3-way conference call with me, so one company can't just keep blaming it on the other company. Barring that... like the guy in the movie "Lorenzo's Oil" I have to solve this one basically on my own. It's sad the tech support for today's products doesn't match the zeal of the sales team. Dave in Las Vegas |
I appreciate your unwillingness to try all those steps, but really, it will take you all of about 10 minutes to do most of them and maybe 20 minutes if you have to uninstall/reinstall Pro Tools. Given that a vast majority of calls we get here in tech support are solved by going through that list of troubleshooting, I think it's in your best interest to do them and let us know if your problems are still unsolved or if you noticed any changes after a particular troubleshooting step. Also, we absolutely, positively need your Sandra report so we can see what we're working with computer-wise. We do not 'pass the buck' between Digi and M-Audio unless there is a clear cut reason for doing so. We're definitely interested in solving your problems, however we do require that you work with us on putting in the effort - we created that Setup and General Troubleshooting thread for a reason - it solves problems. Simple as that. Once we know you've done all that, we can dig deeper into the issue. |
OK, get it. Play by the rules.
I DID get this response from your online e-mail tech support yesterday: Please remove Pro Tools using the instructions in this Answerbase article: http://www.digidesign.com/index.cfm?...0&itemid=27391 Uninstall the M-Audio control panel/Driver you have installed. Reinstall the driver for the firewire solo that was working properly. Make sure that the firewire solo is working properly. Reinstall Pro Tools M-Powered again. I did all this. Crash. Crash. Crash. Sandra report coming up. In the meantime, I have purchased a separate M-audio interface unit at no small expense to see whether replacing the suspect M-Audio unit in the chain solves the problem. If it does... I think my next step will be to approach M-Audio with a whole new set of questions, based on the latest empirical evidence. Dave in Vegas News Anchor, CBS Affiliate in Las Vegas, KLAS-TV http://www.lasvegasnow.com voice-actor: http://www.courvo.com Blog: http://www.courvo.biz (following this saga online) |
Thank you DigiTechSupt and your online tech support people too... you are making me a believer in the process, and I'm happy to admit when I'm wrong.
I hooked up a new M-Audio interface last night to test the efficacy of my theory about the M-Audio unit being the culprit. Uninstalled the FireWire Solo drivers Reboot Install the M-Audio Mobile Pre USB software using CD that came packaged with it. Reboot Install the M-Audio Mobile Pre Drivers Reboot Uninstall Pro-Tools 7.4 Reboot Re-Install Pro-Tools 7.3 Reboot Launch Pro-Tools.... <CRASH> So.... my guess is that it's NOT the M-Audio unit as I suggested. I'm pouring through your trouble-shooting tips and links on DigiDesign. I've tried most of the simpler suggestions. 'Have not yet done Sandra...but will by this evening. Diggin' deeper, and appreciating your help. Dave in Vegas |
OK, here's my Sandra report on my current set-up: (more after that)
Dave in Vegas ________________________________ SiSoftware Sandra System Host Name : DAW User : Dave Workgroup : MSHOME Processor Model : Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz Speed : 2.67GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, Inclusive, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, Inclusive, 64 byte line size, 2 threads sharing System System : System manufacturer P5E Mainboard : ASUSTeK Computer INC. P5E Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : 1 Processor(s) Multi-Processor Advanced PIC (APIC) : Yes System BIOS : American Megatrends Inc. 8.12 Total Memory : 2.00GB DDR3 Chipset 1 Model : ASUS (Bearlake) Processor to I/O Controller Front Side Bus Speed : 4x 334MHz (1.34GHz) Total Memory : 1GB DDR3 Memory Bus Speed : 2x 401MHz (802MHz) Video System Monitor/Panel : SyncMaster 203B(Digital) Adapter : ASUS X1950 Series Adapter : ASUS X1950 Series Secondary Imaging Device : Canon MP210 ser Imaging Device : USB Dual-mode Camera Physical Storage Devices WDC WD5000ABYS-01TNA0 3.5" 500GB (SATA300, NCQ, 16MB Cache) : 465.76GB (C:) Generic STORAGE DEVICE (USB) : N/A (D:) Generic STORAGE DEVICE (USB) : N/A (E:) Generic STORAGE DEVICE (USB) : N/A (G:) Generic STORAGE DEVICE (USB) : N/A (H:) SONY DVD-ROM DDU1615 (ATAPI66, 40x CD-R, 5x DVD-R, 2MB Cache) : N/A (M:) LITE-ON DVDRW LH-20A1H (ATAPI66, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache) : N/A (N:) Logical Storage Devices Hard Disk (C:) : 465.75GB (398.83GB, 86% Free Space) (NTFS) @ WDC WD5000ABYS-01TNA0 3.5" 500GB (SATA300, NCQ, 16MB Cache) CD-ROM/DVD (M:) : N/A @ SONY DVD-ROM DDU1615 (ATAPI66, 40x CD-R, 5x DVD-R, 2MB Cache) CD-ROM/DVD (N:) : N/A @ LITE-ON DVDRW LH-20A1H (ATAPI66, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache) 3.5" 1.44MB (A:) : N/A @ WDC WD5000ABYS-01TNA0 3.5" 500GB (SATA300, NCQ, 16MB Cache) Removable Drive (D:) : N/A @ Generic STORAGE DEVICE (USB) Removable Drive (E:) : N/A @ Generic STORAGE DEVICE (USB) Removable Drive (G:) : N/A @ Generic STORAGE DEVICE (USB) Removable Drive (H:) : N/A @ Generic STORAGE DEVICE (USB) Peripherals USB Controller/Hub : NEC PCI to USB Open Host Controller USB Controller/Hub : NEC PCI to USB Open Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2934 USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2935 USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2936 USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2937 USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2938 USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2939 USB Controller/Hub : Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A USB Controller/Hub : Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : Generic USB Hub USB Controller/Hub : Generic USB Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Printing Support USB Controller/Hub : USB Mass Storage Device USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Composite Device FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller Keyboard : Logitech PS/2 Keyboard Keyboard : Logitech HID-Compliant Keyboard Keyboard : HID Keyboard Device Mouse : Microsoft USB Wireless Mouse (IntelliPoint) Mouse : Logitech HID-compliant Cordless Mouse Mouse : HID-compliant mouse Human Interface : HID Non-User Input Data Filter Human Interface : HID-compliant consumer control device Human Interface : HID-compliant device Human Interface : HID-compliant device Human Interface : HID-compliant device Human Interface : HID-compliant device Human Interface : HID-compliant consumer control device Human Interface : HID-compliant consumer control device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Printers and Faxes Model : QuickBooks PDF Converter Model : Microsoft XPS Document Writer Model : Microsoft Office Document Image Writer Model : Canon MP210 series Printer Model : Adobe PDF Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 2) Platform Compliance : Win32 x86 Network Services Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller Adapter : Linksys Wireless-G PCI Adapter Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. _____________________________________ MAINBOARD below (more after that) _______________________________________ SiSoftware Sandra System Manufacturer : System manufacturer Model : P5E Family : To Be Filled By O.E.M. Version : System Version Serial Number : System Serial Number ID : 11005D60-800100D8-1D00578F-4DE3AA60 SKU Number : To Be Filled By O.E.M. System Chassis Manufacturer : Chassis Manufacture Type : Desktop Can be locked : No Version : Chassis Version Power Cord(s) : 1 Serial Number : Chassis Serial Number Asset Tag : Asset-1234567890 Boot-up State : Safe Power State : Safe Thermal State : Safe Security State : External Interface Locked-out Mainboard Manufacturer : ASUSTeK Computer INC. Multi-Processor (MP) Support : 1 Processor(s) MPS Version : 1.40 Model : P5E Type : Mainboard Version : Rev 1.xx Serial Number : MS1C79B55701247 Asset Tag : To Be Filled By O.E.M. Location in Chassis : To Be Filled By O.E.M. System BIOS : 65-0601-000001-00101111-012408-Bearlake System Mainboard Properties Removable : No Replaceable : Yes Hot Swap : No On-board Devices Onboard Ethernet : Ethernet Adapter (Enabled) System Memory Controller Location : Mainboard Error Correction Capability : None Number of Memory Slots : 4 Maximum Installable Memory : 2GB BANK0 - DIMM0 : Manufacturer0 PartNum0 SerNum0 AssetTagNum0 DIMM Synchronous DDR2 1GB/64 @ 800MHz BANK1 - DIMM1 : Empty BANK2 - DIMM2 : Manufacturer2 PartNum2 SerNum2 AssetTagNum2 DIMM Synchronous DDR2 1GB/64 @ 800MHz BANK3 - DIMM3 : Empty Chipset 1 Model : ASUS (Bearlake) Processor to I/O Controller Revision : A2 Bus : Intel AGTL+ Independent FSB Channels : 1 Front Side Bus Speed : 4x 334MHz (1.34GHz) Maximum FSB Speed : 4x 400MHz (1.60GHz) Width : 64-bit I/O Queue Depth : 12 request(s) Maximum Bus Bandwidth : 10.44GB/s Features TXT - Trust Execution Technology : Yes Unknown : Yes VT-d - Virtualisation Technology : Yes EF - EastFork Technology : Yes AP - Agent Presence : Yes CB - Circuit Breaker : Yes Chipset 1 Hub Interface Type : DMI (Direct Media Interface) Version : 1.00 Number of Ports : 4 In/Out Width : 4-bit / 4-bit Multiplier : 3/1x Speed : 1x 100MHz (100MHz) Logical/Chipset 1 Memory Banks Bank 0 : 512MB DDR3 5.0-5-5-18 CR2 Bank 1 : 512MB DDR3 5.0-5-5-18 CR2 Maximum Installable Memory : 8GB Supported Memory Types : ECC DDR2 DDR3 Channels : 1 Memory Bus Speed : 2x 401MHz (802MHz) Maximum Memory Speed : 2x 800MHz (1.60GHz) Multiplier : 6/5x Width : 64-bit Memory Controller in Processor : No Performance Acceleration Technology : Yes Refresh Rate : 7.80µs Power Save Mode : No Fixed Hole Present : No Maximum Memory Bus Bandwidth : 6.27GB/s APIC 1 Version : 2.00 Multiplier : 1/2x Maximum Interrupts : 24 IRQ Handler Engaged : Yes Enhanced Support : Yes Memory Module 1 Manufacturer : Kingston Model : KTC1G-UDIMM Serial Number : C30FF409 Type : 1GB DIMM DDR2 Technology : 16x(64Mx8) Speed : PC2-6400U DDR2-400 Standard Timings : 5.0-5-5-18 Version : 1.2 Date of Manufacture : Monday, August 06, 2007 Memory DC Line : 1.80V Set Timing @ 400MHz : 5.0-5-5-18 Set Timing @ 267MHz : 4.0-3-3-12 Set Timing @ 200MHz : 3.0-3-3-9 Memory Module 2 Manufacturer : Kingston Model : KTC1G-UDIMM Serial Number : CA0F2449 Type : 1GB DIMM DDR2 Technology : 16x(64Mx8) Speed : PC2-6400U DDR2-400 Standard Timings : 5.0-5-5-18 Version : 1.2 Date of Manufacture : Monday, August 06, 2007 Memory DC Line : 1.80V Set Timing @ 400MHz : 5.0-5-5-18 Set Timing @ 267MHz : 4.0-3-3-12 Set Timing @ 200MHz : 3.0-3-3-9 Environment Monitor 1 Model : Winbond W83627DHG-A ISA Version : 12.01 Mainboard Specific Support : No Temperature Sensor(s) Board Temperature : 35.00°C CPU Temperature : 16.50°C td Cooling Device(s) Auto Fan Speed Control : Yes CPU Fan : 1824rpm Auxliary Fan : 1834rpm Voltage Sensor(s) CPU DC Line : 1.28V Aux DC Line : 3.25V +3.3V DC Line : 3.25V +5V DC Line : 5.28V +12V DC Line : 11.42V Standby DC Line : 3.25V Battery DC Line : 2.61V PCI Bus(es) on Hub 1 Version : 2.30 Number of Bridges : 5 PCI Bus 0 : PCI (1/1x PCIClk) PCI Bus 1 : PCIe (3/1x PCIClk) PCI Bus 2 : PCIe (3/1x PCIClk) PCI Bus 3 : PCIe (3/1x PCIClk) PCI Bus 4 : PCIe (3/1x PCIClk) PCI Bus 5 : PCI (1/1x PCIClk) Number of PCIe Lanes : 19 LPC Hub Controller 1 Model : ASUS (ICH9) LPC Interface Controller Revision : A3 ACPI Power Management Enabled : Yes Advanced TCO Mode Support : Yes Advanced TCO Mode Enabled : No High Precision Timer Enabled : Yes Number of Precision Timers : 4 System Timer : 14.32MHz Delayed Transaction Enabled : Yes LPC Hub Controller 2 Model : ASUS (ICH9) SMBus Controller Revision : A3 USB Controller 1 Model : ASUS (ICH9) USB Universal Host Controller Revision : A3 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 2 Model : ASUS (ICH9) USB Universal Host Controller Revision : A3 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 3 Model : ASUS (ICH9) USB Universal Host Controller Revision : A3 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 4 Model : ASUS (ICH9) USB2 Enhanced Host Controller Revision : A3 Version : 2.00 Specification : 1.00 Interface : EHCI Channels : 6 Companion Controllers : 3 Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support : 64-bit Legacy Emulation Enabled : No USB Controller 5 Model : ASUS (ICH9) USB Universal Host Controller Revision : A3 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 6 Model : ASUS (ICH9) USB Universal Host Controller Revision : A3 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 7 Model : ASUS (ICH9) USB Universal Host Controller Revision : A3 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 8 Model : ASUS (ICH9) USB2 Enhanced Host Controller Revision : A3 Version : 2.00 Specification : 1.00 Interface : EHCI Channels : 6 Companion Controllers : 3 Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support : 64-bit Legacy Emulation Enabled : No FireWire/1394 Controller 1 Model : ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller Revision : M1 Version : 1.10 Interface : OHCI Enhanced Support : No Channels : 64 Speed : 400MHz System SMBus Controller 1 Model : Intel 801xx/63xx SMBus Version : 0.02 Specification : 2.00 Advanced TCO Mode Enabled : Yes Slave Device Enabled : Yes PEC Support : Yes Speed : 100kHz Expansion Slot(s) PCIEX16_1 (1h) : PCIe 32-bit +3.3V Shared PME Half-Length Available (Intel (Bearlake) PCI Express Root Port) PCIEX1_1 (2h) : PCI-X 32-bit +3.3V Shared PME Half-Length Available (ASUS Radeon X1950 Pro (PCIE)) PCIEX1_2 (3h) : PCI-X 32-bit +3.3V Shared PME Half-Length Used (ASUS Radeon X1950 Pro (PCIE)) PCIEX16_2 (4h) : PCIe 32-bit +3.3V Shared PME Half-Length Available PCIEX1_3 (5h) : PCI-X 32-bit +3.3V Shared PME Half-Length Available (ASUS Radeon X1950 Pro (PCIE)) PCI_1 (6h) : PCI 32-bit +3.3V Shared PME Half-Length Available PCI_2 (7h) : PCI 32-bit +3.3V Shared PME Half-Length Available Port Connector(s) PS/2 Keyboard - PS/2 Keyboard : Keyboard / PS/2 USB1_2 - USB1_2 : USB / USB USB3_4 - USB3_4 : USB / USB USB5_6 - USB5_6 : USB / USB PCIE GbE LAN - PCIE GbE LAN : Network / RJ-45 PCIE GbE LAN - PCIE GbE LAN : Network / RJ-45 SPDIF_O12 - SPDIF_OUT12 : Audio / CD-ROM Sound Input IEEE1394 - IEEE1394 : FireWire/1394 Audio Line Out1 - Audio Line Out1 : Audio / Mini-jack Audio Line Out2 - Audio Line Out2 : Audio / Mini-jack Audio Line Out3 - Audio Line Out3 : Audio / Mini-jack Audio Line Out4 - Audio Line Out4 : Audio / Mini-jack Audio Line Out5 - Audio Line Out5 : Audio / Mini-jack Audio Line Out6 - Audio Line Out6 : Audio / Mini-jack LCD_CON - LCD_CON : Audio / Mini-jack SATA12 : SATA SATA34 : SATA SATA56 : SATA PRI_EIDE : SATA FLOPPY : Floppy Disk USB7_8 : USB / USB USB9_10 : USB / USB USB11_12 : USB / USB CD : Audio / CD-ROM Sound Input AAFP : Audio / Mini-jack CPU_FAN : None CHA_FAN1 : None CHA_FAN2 : None CHA_FAN3 : None OPT_FAN1 : None OPT_FAN2 : None OPT_FAN3 : None PWR_FAN : None OPT_TEMP1 : None OPT_TEMP2 : None OPT_TEMP3 : None SPDIF_OUT : Audio / CD-ROM Sound Input IE1394_2 : FireWire/1394 / FireWire/1394 Performance Tips Notice 224 : SMBIOS/DMI information may be inaccurate. Tip 2511 : Some memory slots are free so the memory can be easily upgraded. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. _________________________________ PROCESSOR (more still, after that) _________________________________ SiSoftware Sandra Processor Model : Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz Speed : 2.67GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Bus : Intel AGTL+ Package : FC LGA775 Rated Speed/FSB : 2.66GHz / 4x 333MHz Multiplier : 8/1x Minimum/Maximum Multiplier : 6/1x / 8/1x Generation : G8 Name : C2DC (Conroe) Core 2 Duo 65nm 2.4-3.33GHz 1.0375-1.3V Revision/Stepping : F / B (0) Stepping Mask : G0 Microcode : MU06FBB6 Core Voltage Rating : 1.325V Min/Max Core Voltage : 0.825V / 1.325V Maximum Physical / Virtual Addressing : 36-bit / 48-bit Native Page Size : 4kB Part Number : To Be Filled By O.E.M. Asset Tag : To Be Filled By O.E.M. Serial Number : To Be Filled By O.E.M. Co-Processor (FPU) Speed : 2.67GHz Type : Built-in Revision/Stepping : F / B (0) Cache Information Internal Data Cache : 32kB, Synchronous, Write-Thru, 8-way, Inclusive, 64 byte line size Internal Instruction Cache : 32kB, Synchronous, Write-Back, 8-way, Inclusive, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, Inclusive, 64 byte line size, 2 threads sharing L2 Cache Multiplier : 1/1x Upgradeability Socket/Slot : LGA775 Upgrade Interface : Socket LGA775 Supported Speed(s) : 3.80GHz Processor Power Management Processor Throttling Support : Yes Throttle Range : 75% - 100% Environment Monitor 1 Model : Winbond W83627DHG-A ISA Version : 12.01 Mainboard Specific Support : No Power Rating(s) CPU Core Power : 52.71W Sensors CPU Temperature : 17.50°C td Auto Fan Speed Control : Yes CPU Fan : 1875rpm CPU DC Line : 1.29V Features FPU - Co-Processor Built-in : Yes VME - Virtual Mode Extensions : Yes DE - Debugging Extension : Yes PSE - Page Size Extension : Yes TSC - Time Stamp Counter : Yes MSR - Model Specific Registers : Yes PAE - Physical Address Extension : Yes MCE - Machine Check Exception : Yes CX8 - Compare & Exchange 8-bytes Instruction : Yes APIC - Local APIC Built-in : Yes SEP - Fast System Call : Yes MTRR - Memory Type Range Registers : Yes PGE - Page Global Enable : Yes MCA - Machine Check Architecture : Yes PAT - Page Attribute Table : Yes PSE36 - 36-bit Page Size Extension : Yes PSN - Unique Serial Number : No CLF - Cache Line Flush Support : Yes DS - Debug Trace & EMON Store : Yes ACPI - Software Clock Control : Yes (W)MMX Technology : Yes FXSR - Fast Float Save & Restore : Yes SSE Technology : Yes SSE2 Technology : Yes SS - Self Snoop : Yes HTT - Hyper-Threading Technology : No TM - Thermal Monitor : Yes PBE - Pending Break Enable : Yes IA64 Technology : No SSE3 Technology : Yes MON - Monitor/MWait : Yes DSCPL - CPL qualified Debug Store : Yes VMX - Virtual Machine eXtensions : Yes TXT - Trust Execution Technology : Yes EIST - Enhanced SpeedStep Technology : Yes TM2 - Thermal Monitor 2 : Yes Supplemental SSE3 Technology : Yes CID - Context ID : No CX16 - Compare & Exchange 16-bytes Instruction : Yes xTPR - Send Task Priority Messages : Yes DCA - Direct Cache Access : No SSE4.1 Technology : No SSE4.2 Technology : No x2APIC - v2 APIC Mode : No POPCNT - Pop Count : No DAZ - Denormals Are Zero : Yes Extended Features EMMX - Extended MMX Technology : No 3DNow! Technology : No Extended 3DNow! Technology : No XD/NX - No-execute Page Protection : Yes AMD64/EM64T Technology : Yes Power Management Features DTSC - Digital Thermal Sensor Capability : Yes IDA - Dynamic Acceleration Technology : No HCFC - Hardware Coordination Feedback Capability : Yes Advanced Settings Data Error Checking : No I/O Queue Depth : 8 request(s) PM - Performance Monitoring Support : Yes PEBS - Precise Event Based Sampling Support : Yes TM - Thermal Monitor : Yes TM2 - Thermal Monitor 2 : No EIST - Enhanced SpeedStep Technology : Yes Symmetric Multiprocessing (SMP) Settings Bootstrap CPU : Yes Global APIC Engaged : Yes APIC Cluster ID : 0 Arbitration ID : 0 Machine Check Architecture Settings Number of Reporting Banks : 6 bank(s) Variable Range MTRR Settings MTRR 0 : 00000000-7FFFFFFF WB Fixed Range MTRR Settings MTRR 0 Range 0 : 00000000-0000FFFF (0kB-64kB) WB MTRR 0 Range 1 : 00010000-0001FFFF (64kB-128kB) WB MTRR 0 Range 2 : 00020000-0002FFFF (128kB-192kB) WB MTRR 0 Range 3 : 00030000-0003FFFF (192kB-256kB) WB MTRR 0 Range 4 : 00040000-0004FFFF (256kB-320kB) WB MTRR 0 Range 5 : 00050000-0005FFFF (320kB-384kB) WB MTRR 0 Range 6 : 00060000-0006FFFF (384kB-448kB) WB MTRR 0 Range 7 : 00070000-0007FFFF (448kB-512kB) WB MTRR 1 Range 0 : 00080000-00083FFF (512kB-528kB) WB MTRR 1 Range 1 : 00084000-00087FFF (528kB-544kB) WB MTRR 1 Range 2 : 00088000-0008BFFF (544kB-560kB) WB MTRR 1 Range 3 : 0008C000-0008FFFF (560kB-576kB) WB MTRR 1 Range 4 : 00090000-00093FFF (576kB-592kB) WB MTRR 1 Range 5 : 00094000-00097FFF (592kB-608kB) WB MTRR 1 Range 6 : 00098000-0009BFFF (608kB-624kB) WB MTRR 1 Range 7 : 0009C000-0009FFFF (624kB-640kB) WB MTRR 2 Range 0 : 000A0000-000A3FFF (640kB-656kB) UC MTRR 2 Range 1 : 000A4000-000A7FFF (656kB-672kB) UC MTRR 2 Range 2 : 000A8000-000ABFFF (672kB-688kB) UC MTRR 2 Range 3 : 000AC000-000AFFFF (688kB-704kB) UC MTRR 2 Range 4 : 000B0000-000B3FFF (704kB-720kB) UC MTRR 2 Range 5 : 000B4000-000B7FFF (720kB-736kB) UC MTRR 2 Range 6 : 000B8000-000BBFFF (736kB-752kB) UC MTRR 2 Range 7 : 000BC000-000BFFFF (752kB-768kB) UC MTRR 3 Range 0 : 000C0000-000C0FFF (768kB-772kB) WP MTRR 3 Range 1 : 000C1000-000C1FFF (772kB-776kB) WP MTRR 3 Range 2 : 000C2000-000C2FFF (776kB-780kB) WP MTRR 3 Range 3 : 000C3000-000C3FFF (780kB-784kB) WP MTRR 3 Range 4 : 000C4000-000C4FFF (784kB-788kB) WP MTRR 3 Range 5 : 000C5000-000C5FFF (788kB-792kB) WP MTRR 3 Range 6 : 000C6000-000C6FFF (792kB-796kB) WP MTRR 3 Range 7 : 000C7000-000C7FFF (796kB-800kB) WP MTRR 4 Range 0 : 000C8000-000C8FFF (800kB-804kB) WP MTRR 4 Range 1 : 000C9000-000C9FFF (804kB-808kB) WP MTRR 4 Range 2 : 000CA000-000CAFFF (808kB-812kB) WP MTRR 4 Range 3 : 000CB000-000CBFFF (812kB-816kB) WP MTRR 4 Range 4 : 000CC000-000CCFFF (816kB-820kB) WP MTRR 4 Range 5 : 000CD000-000CDFFF (820kB-824kB) WP MTRR 4 Range 6 : 000CE000-000CEFFF (824kB-828kB) WP MTRR 4 Range 7 : 000CF000-000CFFFF (828kB-832kB) WP MTRR 5 Range 0 : 000D0000-000D0FFF (832kB-836kB) WP MTRR 5 Range 1 : 000D1000-000D1FFF (836kB-840kB) WP MTRR 5 Range 2 : 000D2000-000D2FFF (840kB-844kB) WP MTRR 5 Range 3 : 000D3000-000D3FFF (844kB-848kB) WP MTRR 5 Range 4 : 000D4000-000D4FFF (848kB-852kB) WP MTRR 5 Range 5 : 000D5000-000D5FFF (852kB-856kB) WP MTRR 5 Range 6 : 000D6000-000D6FFF (856kB-860kB) WP MTRR 5 Range 7 : 000D7000-000D7FFF (860kB-864kB) WP MTRR 6 Range 0 : 000D8000-000D8FFF (864kB-868kB) WP MTRR 6 Range 1 : 000D9000-000D9FFF (868kB-872kB) WP MTRR 6 Range 2 : 000DA000-000DAFFF (872kB-876kB) WP MTRR 6 Range 3 : 000DB000-000DBFFF (876kB-880kB) WP MTRR 6 Range 4 : 000DC000-000DCFFF (880kB-884kB) WP MTRR 6 Range 5 : 000DD000-000DDFFF (884kB-888kB) WP MTRR 6 Range 6 : 000DE000-000DEFFF (888kB-892kB) WP MTRR 6 Range 7 : 000DF000-000DFFFF (892kB-896kB) WP MTRR 7 Range 0 : 000E0000-000E0FFF (896kB-900kB) WT MTRR 7 Range 1 : 000E1000-000E1FFF (900kB-904kB) WT MTRR 7 Range 2 : 000E2000-000E2FFF (904kB-908kB) WT MTRR 7 Range 3 : 000E3000-000E3FFF (908kB-912kB) WT MTRR 7 Range 4 : 000E4000-000E4FFF (912kB-916kB) WT MTRR 7 Range 5 : 000E5000-000E5FFF (916kB-920kB) WT MTRR 7 Range 6 : 000E6000-000E6FFF (920kB-924kB) WT MTRR 7 Range 7 : 000E7000-000E7FFF (924kB-928kB) WT MTRR 8 Range 0 : 000E8000-000E8FFF (928kB-932kB) WT MTRR 8 Range 1 : 000E9000-000E9FFF (932kB-936kB) WT MTRR 8 Range 2 : 000EA000-000EAFFF (936kB-940kB) WT MTRR 8 Range 3 : 000EB000-000EBFFF (940kB-944kB) WT MTRR 8 Range 4 : 000EC000-000ECFFF (944kB-948kB) WT MTRR 8 Range 5 : 000ED000-000EDFFF (948kB-952kB) WT MTRR 8 Range 6 : 000EE000-000EEFFF (952kB-956kB) WT MTRR 8 Range 7 : 000EF000-000EFFFF (956kB-960kB) WT MTRR 9 Range 0 : 000F0000-000F0FFF (960kB-964kB) WP MTRR 9 Range 1 : 000F1000-000F1FFF (964kB-968kB) WP MTRR 9 Range 2 : 000F2000-000F2FFF (968kB-972kB) WP MTRR 9 Range 3 : 000F3000-000F3FFF (972kB-976kB) WP MTRR 9 Range 4 : 000F4000-000F4FFF (976kB-980kB) WP MTRR 9 Range 5 : 000F5000-000F5FFF (980kB-984kB) WP MTRR 9 Range 6 : 000F6000-000F6FFF (984kB-988kB) WP MTRR 9 Range 7 : 000F7000-000F7FFF (988kB-992kB) WP MTRR 10 Range 0 : 000F8000-000F8FFF (992kB-996kB) WP MTRR 10 Range 1 : 000F9000-000F9FFF (996kB-1000kB) WP MTRR 10 Range 2 : 000FA000-000FAFFF (1000kB-1004kB) WP MTRR 10 Range 3 : 000FB000-000FBFFF (1004kB-1008kB) WP MTRR 10 Range 4 : 000FC000-000FCFFF (1008kB-1012kB) WP MTRR 10 Range 5 : 000FD000-000FDFFF (1012kB-1016kB) WP MTRR 10 Range 6 : 000FE000-000FEFFF (1016kB-1020kB) WP MTRR 10 Range 7 : 000FF000-000FFFFF (1020kB-1024kB) WP PAT Settings PAT 0 : WB PAT 1 : WC PAT 2 : UC- PAT 3 : UC PAT 4 : WB PAT 5 : WC PAT 6 : UC- PAT 7 : UC Performance Tips Tip 210 : Mainboard supports faster CPUs, so the CPU can be upgraded when needed. _______________________________ OPERATING SYSTEM BELOW _______________________________ SiSoftware Sandra General Information Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 2) Platform Compliance : Win32 x86 Full Name : Microsoft Windows XP 5.1.2600 : Service Pack 2 Kernel Type : Multiprocessor Free No of Licenced Processor Sockets : 2 BackOffice Components : No Small Business Components : No Terminal Services Components : No Compute Cluster Components : No Product ID : 76487-OEM-0045525-02062 Product Key : F347D-6P86H-9YRY6-WRHWQ-M4246 Registered Owner : Home Registered Organisation : Home Activation Status Activation Required : No Data Execution Prevention (DEP) Supported by CPU : Yes Applications Protected : Yes Drivers Protected : Yes Virtual Machines and Runtime Engines .NET Framework : 3.1.21022 (SP1) Windows Communication Foundation : 3.0.4506 Windows Presentation Foundation : 3.0.6920 Windows Workflow Foundation : 3.0.4203 .NET Framework : 2.1.21022 (SP1) .NET Framework : 1.1.4322 (SP1) Java Runtime Engine : 1.6.0 Default Key Applications Web Browser : Internet Explorer 7.00.6000.16608 E-mail : Microsoft Office Outlook 11.00.8169 News Reader : Outlook Express 6.00.2900.2180 Media Player : Windows Media Player 11.00.5721.5145 Internet Call : NetMeeting 5.01.2600.2180 Calendar/Organiser : Microsoft Office Outlook 11.00.8169 Address Book : Microsoft Office Outlook 11.00.8169 Anti-Virus : AVG 7.5.516 7.5.516 Session Settings Host Name : DAW User : Dave Display Scheme : Windows Standard Time Since Start-Up : 17 hour(s) 34 minutes(s) 14 seconds(s) OS Properties Debug Version : No Security Present : No Remote Terminal Session : No Boot Features Boot Type : Normal Automatic Update Active Service : Yes Status : Automatic Scheduled Day : Every Day Scheduled Time : 3:00:00 AM Installed Windows Updates Microsoft .NET Framework version 1.1 : Updates, Windows XP (23.14MB) Windows Messenger 4.7 : Updates, Windows XP (981.66kB) 816093: Security Update Microsoft Virtual Machine (Microsoft VM) : Critical, Security Updates, Windows XP (5.07MB) Critical Update for Office XP on Windows XP Service Pack 2 (KB885884) : Critical Updates, Windows XP (4.34MB) Security Update for Windows XP (KB873339) : Important, Security Updates, Windows XP (334.02kB - 597.73kB) Critical Update for Windows XP (KB886185) : Critical Updates, Windows XP (384.23kB) Security Update for Windows XP (KB885836) : Important, Security Updates, Windows XP (341.53kB - 516.23kB) Critical Update for Windows XP (KB885626) : Critical Updates, Windows XP (458.73kB) Security Update for Windows XP (KB888302) : Important, Security Updates, Windows XP (329.53kB - 386.73kB) Security Update for Windows Messenger (KB887472) : Moderate, Security Updates, Windows XP (330.28kB - 1.03MB) Security Update for Windows XP (KB891781) : Important, Security Updates, Windows XP (333.01kB - 396.23kB) Security Update for Windows XP (KB885835) : Important, Security Updates, Windows XP (393.30kB - 2.96MB) Microsoft Windows Installer 3.1 : Critical Updates, Windows XP (2.47MB) Security Update for Windows XP (KB896428) : Moderate, Security Updates, Windows XP (470.47kB - 512.73kB) Update for Windows XP (KB896344) : Updates, Windows XP (1.27MB) Security Update for Windows XP (KB901214) : Critical, Security Updates, Windows XP (469.66kB - 611.23kB) Update for Windows XP (KB898461) : Critical Updates, Windows XP (476.73kB) Security Update for Windows XP (KB890859) : Important, Security Updates, Windows XP (1.32MB - 5.82MB) Security Update for Windows XP (KB896358) : Critical, Security Updates, Windows XP (684.90kB - 1014.23kB) Security Update for Windows XP (KB893756) : Important, Security Updates, Windows XP (491.10kB - 675.23kB) Beta 6.2 Installer version Security Update for Windows XP (KB899591) : Important, Security Updates, Windows XP (488.66kB - 577.23kB) Security Update for Windows XP (KB899591) : Moderate, Security Updates, Windows XP (481.66kB - 570.23kB) Security Update for Windows XP (KB899587) : Moderate, Security Updates, Windows XP (559.52kB - 720.23kB) Security Update for Windows XP (KB896423) : Critical, Security Updates, Windows XP (494.06kB - 550.23kB) Update for Windows XP (KB894391) : Critical Updates, Windows XP (705.72kB - 1.98MB) Security Update for JView Profiler (KB903235) : Critical, Security Updates, Windows XP (483.23kB) Microsoft GDI+ Detection Tool (KB873374) : Critical Updates, Windows XP (213.51kB) Security Update for Windows XP (KB902400) : Important, Security Updates, Windows XP (1.82MB - 4.71MB) Security Update for Windows XP (KB901017) : Important, Security Updates, Windows XP (599.83kB - 1021.73kB) Security Update for Windows XP (KB905414) : Moderate, Security Updates, Windows XP (53.29kB - 606.73kB) Security Update for Windows XP (KB905749) : Important, Security Updates, Windows XP (480.48kB - 568.73kB) Security Update for Windows XP (KB900725) : Important, Security Updates, Windows XP (1.51MB - 4.93MB) Update for WMDRM-enabled Media Players (KB891122) : Updates, Windows XP (5.91MB) Microsoft Base Smart Card Cryptographic Service Provider Package: x86 (KB909520) : Updates, Windows XP (626.28kB) Update for Windows XP (KB910437) : Critical Updates, Windows XP (1.14MB) Security Update for Windows XP (KB908519) : Critical, Security Updates, Windows XP (181.63kB - 583.23kB) Microsoft .NET Framework 2.0: x86 (KB829019) : Updates, Windows XP (22.42MB) Security Update for Windows XP (KB911927) : Important, Security Updates, Windows XP (181.34kB - 603.73kB) Security Update for Windows Media Player 9 (KB911565) : Critical, Security Updates, Windows XP (2.19MB) Security Update for Windows XP (KB901190) : Important, Security Updates, Windows XP (147.65kB - 530.73kB) Security Update for Windows Media Player Plug-in (KB911564) : Important, Security Updates, Windows XP (597.26kB) Security Update for Windows XP (KB911562) : Critical, Security Updates, Windows XP (196.95kB - 560.73kB) Update for Windows XP (KB900485) : Critical Updates, Windows XP (149.22kB - 571.23kB) Security Update for Windows XP (KB908531) : Critical, Security Updates, Windows XP (789.19kB - 4.44MB) Update for Windows XP (KB883921) : Updates, Windows XP (3.02MB) Update for Windows XP SP2 Bulgarian Language Interface Pack (KB883921) : Updates, Windows XP (801.73kB) Update for Windows XP SP2 Croatian Language Interface Pack (KB883921) : Updates, Windows XP (794.23kB) Update for Windows XP SP2 Estonian Language Interface Pack (KB883921) : Updates, Windows XP (787.23kB) Update for Windows XP SP2 Hindi Language Interface Pack (KB883921) : Updates, Windows XP (801.22kB) Update for Windows XP SP2 Icelandic Language Interface Pack (KB883921) : Updates, Windows XP (793.73kB) Update for Windows XP SP2 Indonesian Language Interface Pack (KB883921) : Updates, Windows XP (786.73kB) Update for Windows XP SP2 Latvian Language Interface Pack (KB883921) : Updates, Windows XP (788.73kB) Update for Windows XP SP2 Lithuanian Language Interface Pack (KB883921) : Updates, Windows XP (795.23kB) Update for Windows XP SP2 Malay Language Interface Pack (KB883921) : Updates, Windows XP (788.72kB) Update for Windows XP SP2 Romanian Language Interface Pack (KB883921) : Updates, Windows XP (791.23kB) Update for Windows XP SP2 Serbian-Cyrillic Language Interface Pack (KB883921) : Updates, Windows XP (1.05MB) Update for Windows XP SP2 Serbian-Latin Language Interface Pack (KB883921) : Updates, Windows XP (1.04MB) Update for Windows XP SP2 Thai Language Interface Pack (KB883921) : Updates, Windows XP (1.43MB) Security Update for Windows XP (KB914389) : Important, Security Updates, Windows XP (323.66kB - 972.80kB) Security Update for Windows XP (KB918439) : Critical, Security Updates, Windows XP (234.15kB - 553.80kB) Security Update for Windows XP (KB913580) : Low, Security Updates, Windows XP (615.19kB - 1.25MB) Security Update for Windows XP (KB911280) : Important, Security Updates, Windows XP (301.09kB - 1.04MB) Update for Windows XP (KB904942) : Updates, Windows XP (151.38kB - 501.23kB) Security Update for Windows XP (KB914388) : Critical, Security Updates, Windows XP (365.92kB - 994.30kB) Security Update for Windows XP (KB920670) : Important, Security Updates, Windows XP (200.74kB - 511.30kB) Security Update for Windows XP (KB920683) : Critical, Security Updates, Windows XP (196.32kB - 593.30kB) Update for Windows XP (KB922582) : Critical Updates, Windows XP (549.80kB) Update for Windows XP (KB916595) : Critical Updates, Windows XP (156.77kB - 596.73kB) Security Update for Windows XP (KB919007) : Important, Security Updates, Windows XP (202.74kB - 553.80kB) Security Update for Windows XP (KB920685) : Moderate, Security Updates, Windows XP (195.56kB - 1.24MB) Update for Windows XP (KB920872) : Critical Updates, Windows XP (190.83kB - 602.80kB) Service Pack 3 for Business Contact Manager Update and Small Business Accounting : Office 2003, Service Packs (44.44MB) Security Update for Windows XP (KB923414) : Important, Security Updates, Windows XP (184.65kB - 708.30kB) Security Update for Windows XP (KB924496) : Moderate, Security Updates, Windows XP (495.40kB - 1.60MB) Security Update for Windows XP (KB923191) : Critical, Security Updates, Windows XP (1.07MB - 4.04MB) Security Update for Windows XP (KB922819) : Low, Security Updates, Windows XP (289.54kB - 836.30kB) MSXML 6.0 RTM Security Update (925673) : Critical, Security Updates, SQL Server Feature Pack (907.27kB) Network Diagnostic Tool (KB914440) : Tools, Windows XP (665.80kB) Update for Windows XP (KB920342) : Updates, Windows XP (781.79kB - 949.30kB) Security Update for Windows XP (KB924270) : Low, Security Updates, Windows XP (234.27kB - 978.80kB) Update for Windows XP Media Center Edition 2005 (KB926251) : Critical Updates, Windows XP (713.33kB) Security Update for Windows XP (KB923980) : Important, Security Updates, Windows XP (208.45kB - 664.80kB) Security Update for Windows XP (KB926255) : Important, Security Updates, Windows XP (197.47kB - 722.30kB) Security Update for Windows XP (KB929969) : Critical, Security Updates, Windows XP (189.22kB - 783.30kB) Security Update for Windows XP (KB928255) : Important, Security Updates, Windows XP (370.85kB - 2.99MB) Security Update for Windows XP (KB928843) : Critical, Security Updates, Windows XP (157.22kB - 708.38kB) Security Update for Windows XP (KB927802) : Important, Security Updates, Windows XP (196.16kB - 593.80kB) Security Update for Windows XP (KB924667) : Important, Security Updates, Windows XP (1012.63kB - 1.73MB) Security Update for Windows XP (KB927779) : Critical, Security Updates, Windows XP (284.74kB - 768.80kB) Security Update for Windows XP (KB918118) : Important, Security Updates, Windows XP (357.80kB - 875.30kB) Security Update for Windows XP (KB926436) : Important, Security Updates, Windows XP (199.60kB - 524.30kB) February 2007 CardSpace Update for Windows XP (KB925720) : Critical Updates, Windows XP (151.99kB - 610.80kB) Remote Desktop Connection (Terminal Services Client 6.0) for Windows XP (KB925876) : Updates, Windows XP (1.55MB) Windows Media Player 11 : Updates, Windows XP (24.56MB) Security Update for Windows XP (KB925902) : Critical, Security Updates, Windows XP (454.56kB - 1.74MB) Update for Windows Media Format 11 SDK for Windows XP (KB929399) : Critical Updates, Windows XP (626.41kB) Security Update for Windows XP (KB931784) : Important, Security Updates, Windows XP (730.22kB - 2.19MB) Security Update for Windows XP (KB930178) : Critical, Security Updates, Windows XP (191.54kB - 620.38kB) Security Update for Windows XP (KB931261) : Critical, Security Updates, Windows XP (108.80kB - 548.38kB) Security Update for Windows XP (KB932168) : Critical, Security Updates, Windows XP (135.11kB - 562.38kB) Office Accounting 2007 Service Pack 1 : Office 2007, Service Packs (82.70MB) Security Update for Windows XP (KB890046) : Moderate, Security Updates, Windows XP (468.50kB - 510.23kB) Security Update for Windows XP (KB920213) : Critical, Security Updates, Windows XP (248.44kB - 669.30kB) Update for Windows XP (KB930916) : Critical Updates, Windows XP (306.71kB - 776.88kB) Update for Windows XP (KB927891) : Critical Updates, Windows XP (1.21MB) Cumulative Security Update for Outlook Express for Windows XP (KB929123) : Important, Security Updates, Windows XP (307.81kB - 1.53MB) Security Update for Windows XP (KB935840) : Critical, Security Updates, Windows XP (118.58kB - 545.88kB) Security Update for Windows XP (KB935839) : Critical, Security Updates, Windows XP (189.99kB - 783.88kB) Update for .NET Framework 3.0: x86 (KB932471) : Updates, Windows XP (413.42kB) Security Update for Windows Media Player 6.4 (KB925398) : Critical, Security Updates, Windows XP (778.41kB) Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1 (KB928366) : Critical, Security Updates, Windows XP (8.82MB) Update for Windows XP (KB938828) : Critical Updates, Windows XP (192.67kB - 829.88kB) Security Update for Windows XP (KB938829) : Critical, Security Updates, Windows XP (115.71kB - 608.38kB) Security Update for Windows Media Player 11 for Windows XP (KB936782) : Important, Security Updates, Windows XP (5.54MB) Security Update for Microsoft XML Core Services 4.0 Service Pack 2 (KB936181) : Critical, Security Updates, Windows XP (5.39MB) Security Update for Internet Explorer 7 for Windows XP (KB938127) : Critical, Security Updates, Windows XP (212.66kB - 780.38kB) Security Update for Microsoft XML Core Services 6.0 and Microsoft XML Core Services 6.0 Service Pack 1 (KB933579) : Critical, Security Updates, Windows XP (903.85kB) Update for Windows Media Player 11 for Windows XP (KB939683) : Critical Updates, Windows XP (548.41kB) Security Update for Windows XP (KB936021) : Critical, Security Updates, Windows XP (579.14kB - 889.38kB) Security Update for Windows XP (KB933729) : Important, Security Updates, Windows XP (855.38kB) Security Update for Outlook Express for Windows XP (KB941202) : Critical, Security Updates, Windows XP (139.33kB - 770.88kB) Office 2003 Service Pack 3 (SP3) for Proofing Tools : Office 2003, Service Packs (64.30MB) Outlook Live 2003 Service Pack 3 (SP3) : Office 2003, Service Packs (24.92MB) OneNote 2003 Service Pack 3 (SP3) : Office 2003, Service Packs (35.32MB) Project 2003 Service Pack 3 (SP3) : Office 2003, Service Packs (40.76MB) Office 2003 Service Pack 3 (SP3) : Office 2003, Service Packs (119.92MB) Visio 2003 Service Pack 3 (SP3) : Office 2003, Service Packs (48.47MB) Word Viewer 2003 Service Pack 3 (SP3) : Office 2003, Service Packs (12.13MB) Excel Viewer 2003 Service Pack 3 (SP3) : Office 2003, Service Packs (9.76MB) Microsoft .NET Framework 3.0: x86 (KB928416) : Updates, Windows XP (47.32MB) Security Update for Windows XP (KB943460) : Critical, Security Updates, Windows XP (2.97MB) Update for Windows XP (KB936357) : Critical Updates, Windows XP (330.68kB - 691.88kB) Windows Internet Explorer 7 for Windows XP : Update Rollups, Windows XP (14.74MB) Windows Internet Explorer 7 for Windows XP : Updates, Windows XP (14.74MB) Windows Genuine Advantage Validation Tool (KB892130) : Critical Updates, Windows XP (1.07MB) Microsoft .NET Framework 1.1 Service Pack 1 : Service Packs, Windows XP (10.21MB) Update for Windows XP (KB942763) : Update Rollups, Windows XP (102.77kB - 501.04kB) Security Update for Windows XP (KB941568) : Critical, Security Updates, Windows XP (246.32kB - 996.54kB) Security Update for Windows XP (KB944653) : Important, Security Updates, Windows XP (117.56kB - 484.04kB) Update for Outlook 2003 (KB943649) : Critical Updates, Office 2003 (3.80MB) Calendar Printing Assistant for Microsoft Office Outlook Service Pack 1 (SP1) : Office 2007, Service Packs (9.25MB) Security Update for Windows XP (KB937894) : Moderate, Security Updates, Windows XP (325.19kB - 996.38kB) Office 2003 Web Components Service Pack 1 for the 2007 Microsoft Office System : Office 2007, Service Packs (4.63MB) Microsoft Office Visio Viewer 2007 Service Pack 1 (SP1) : Office 2007, Service Packs (6.64MB) Microsoft Office PowerPoint Viewer 2007 Service Pack 1 (SP1) : Office 2007, Service Packs (24.85MB) 2007 Microsoft Office Servers Service Pack 1 (SP1) : Office 2007, Service Packs (2.07MB) 2007 Microsoft Office Servers Service Pack 1 (SP1), 64-bit edition : Office 2007, Service Packs (2.10MB) 2007 Microsoft Office Suite Service Pack 1 (SP1) : Office 2007, Service Packs (50.14MB) Security Update for Windows XP with Windows Media Format Runtime 9.5 and 11 (KB941569) : Critical, Security Updates, Windows XP (2.07MB) Security Update for Windows XP (KB941644) : Critical, Security Updates, Windows XP (157.68kB - 652.04kB) Security Update for Windows XP (KB943485) : Important, Security Updates, Windows XP (189.01kB - 809.54kB) Root Certificates Update : Updates, Windows XP (286.09kB) Microsoft Silverlight 1.0 (KB946609) : Feature Packs, Silverlight (1.79MB) Microsoft .NET Framework 3.0 Service Pack 1 (KB929300) : Service Packs, Windows XP (29.47MB) Microsoft .NET Framework 2.0 Service Pack 1 (KB110806) : Service Packs, Windows XP (23.61MB) Cumulative Security Update for Internet Explorer 7 for Windows XP (KB944533) : Critical, Security Updates, Windows XP (2.19MB - 8.46MB) Security Update for Windows XP (KB946026) : Critical, Security Updates, Windows XP (132.34kB - 557.54kB) Windows Malicious Software Removal Tool - February 2008 (KB890830) : Update Rollups, Windows XP (7.44MB) Security Update for Windows XP (KB943055) : Critical, Security Updates, Windows XP (153.02kB - 725.54kB) Security Update for Office 2003 (KB945185) : Important, Office 2003, Security Updates (1.99MB) Security Update for Microsoft Office Publisher 2003 (KB946254) : Important, Office 2003, Security Updates (2.91MB) Update for Business Contact Manager for Outlook 2007 (KB946140) : Critical Updates, Office 2007 (7.98MB) Update for Office 2003 (KB907417) : Critical Updates, Office 2003 (224.63kB) Update for Outlook Junk Email Filter 2003 (KB944941) : Critical Updates, Office 2003 (3.39MB) Security Update for Microsoft Works Suite 2005 (KB943973) : Moderate, Office 2003, Security Updates (455.80kB) Security Update for Microsoft Office Word 2003 (KB943983) : Important, Office 2003, Security Updates (5.81MB) Available Windows Updates Microsoft Office Compatibility Pack Service Pack 1 (SP1) : Office 2007, Service Packs (24.45MB) Update for Windows Live Sign-In Assistant (KB 947449) : Updates, Windows Live (868.55kB) Regional Settings User Default Locale : 1033 Country : United States Language : English (United States) Currency : $ Time Zone : Pacific Standard Time ANSI Code Page : 1252 OEM Code Page : 437 Operating System Folders Windows Folder : C:\WINDOWS System Folder : C:\WINDOWS\system32 Application Data Path : C:\Documents and Settings\Dave\Desktop Programs Path : C:\Program Files Temporary Folder : C:\WINDOWS\TEMP Performance Tips Warning 1316 : This copy of Windows contains Product Activation Technology. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Win 7 Fast Track Solo - Driver Issue | Arkitorture | FireWire & USB Audio Interfaces (Win) | 9 | 08-12-2013 10:32 AM |
PT8 crashes with new solo shortcut? | Felix Rost | Pro Tools TDM Systems (Mac) | 14 | 03-17-2010 06:25 PM |
PT8: Shift+S to Solo Crashes PT | laki | Pro Tools TDM Systems (Mac) | 13 | 11-16-2009 12:10 PM |
Shift+ S (solo quickkey) crashes system | ragamesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2009 08:47 PM |
Firewire Solo and Firewire External Drive | TrevorForrest | Pro Tools M-Powered (Win) | 6 | 04-28-2006 02:59 PM |
