Old 04-23-2014, 12:16 PM
rob wots's Avatar
rob wots rob wots is offline
Default which is best impedance for headphones?
hi fellow 11R fans,
i searched for this and even though there are a few threads about headphones i couldn't find the answer. does anyone know the best impedance for headphones for the 11R?
thanks in advance :)
eleven rack, pro tools 11 LE
OS win 7 64
fractal design define r4 chassis
m-audio audiophile 24/96 soundcard
intel core i5 4440 3.1 GHz quad core CPU
asus B85M-E Motherboard
corsair vengeance 8GB DDR3 RAM
seagate barracuda 2TB 6bp/s HDD
thermalright 140BW true spirit CPU cooler
samsung dvd writer
corsair CX600 PSU
Old 04-23-2014, 06:21 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: which is best impedance for headphones?
Most,if not all headphones will be impedance matched to any headphone output jack.
If it's quality you're after, then you'll need to rephrase your question.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 04-23-2014, 07:12 PM
The Eleven Rack may not drive some of the higher impedance headphones that well e.g. My Sennheiser HD600s (~300 ohm) sound much better if driven by a proper headphone amplifier connected to line-out. Less of an issue with my lower-end lower impedance Sennheiser headphones. But as said, impedance alone does not a good headphone make.
Old 04-23-2014, 07:58 PM
Lachrae Lachrae is offline
I am glad I came across this thread.
I have a pair of HD 280 Pro, I didn't really expect them to be an issue with the eleven rack. But this is good info to know if I decided to get some more higher-end headphones that have higher impedance. Although at that point I would prolly do just what Darryl above mentioned, and get a decent headphone amp, and come off of the line outs.
Old 04-24-2014, 12:27 AM
rob wots's Avatar
thanks for the reply's, although to be honest i'm none the wiser... :)
yes i agree impedance isn't the only determining factor when it comes to quality but surely some ohms will work better with the 11R phones output than others?
i'm keeping things as compact as i can so i don't want a headphone amp.
my old dt100's are 400 ohm and are on the quiet side with the 11R. they're tatty and need replacing (lasted 16 years though) i'd like to stick with beyerdynamic and go for their 770 pro but just that headphone alone there's a choice of impedance, 32, 80 and 250 ohm does anyone know which impedance suits the 11R phones output best? i thought the lower the ohms the more they'd distort at high volume, and the higher the ohm the more power you needed to drive them. have i got it wrong?
i'll be using them mostly for recording guitars and vocals, don't know if that makes any difference?
OS win 7 64
samsung dvd writer
corsair CX600 PSU
Old 04-24-2014, 05:54 AM
This is my understanding of it as well, but that doesn't mean I am right.
Old 04-25-2014, 05:25 AM
abzic abzic is offline
I have the Sennheiser HD 280 Pro (64ohms) and the Beyerdynamic DT 880 Pro (250ohms). As expected the DT 880 Pro is more quiet but perfectly okay with 11 Rack. If I was to keep just one it would be the DT 880 Pro, it also costs twice as much as the HD 280 Pro, that says something too.
Old 04-25-2014, 07:58 AM
rob wots's Avatar
lol...we're a right pair of boffins :)
are your HD 280 pro 64 ohms like abzics? and if they are do you get any distortion at higher volumes?
OS win 7 64
samsung dvd writer
corsair CX600 PSU
Old 04-25-2014, 08:01 AM
rob wots's Avatar
thanks, that's good to know that the 250's are ok with it. do your 64 ohm HD 280 pro's distort at all at high volume? if not then the 80 ohm 770's i've been looking at should be fine too :)
OS win 7 64
samsung dvd writer
corsair CX600 PSU
Old 04-25-2014, 02:30 PM
I haven't noticed any distortion at normal listening levels. I will try pushing the volume tonight and report back.
Headphone Impedance Djent Eleven Rack 6 11-24-2011 09:34 PM
SM57 Impedance Mod Jwald Eleven Rack 2 11-04-2010 03:01 AM
headphone impedance blackaxe Pro Tools TDM Systems (Mac) 1 07-13-2005 07:35 PM
Headphones + impedance Tubthumper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-29-2004 06:50 PM
Variable impedance, how? wonderfall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-07-2004 07:31 AM
