2nd graphics card for Mac Pro
I need to get a 2nd graphics card to work in a Mac Pro dual 3ghz tower. I took an NVIDIA card from a Quad G5, but can't seem
to get it to work together with the Mac Pro card. Anyone know the correct setting in the Expansion Slot Utility or what slot the second card has to go into? The final config will be 2 graphics cards and an HD2 setup. Thanks, Steve
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
Re: 2nd graphics card for Mac Pro
This will not work - you can only have 1 graphics card installed, otherwise you'll run into all kinds of PCI bus errors due to the graphics card and the HD cards fighting for control of the PCI bus...
So I guess my question is what changed and when? |
While some people have been able to use a 2nd graphics card successfully, the vast majority will see severe issues when doing so. If someone calls in with problems, the first thing we'll have them do is remove that 2nd graphics card since it's not supported, nor recommended. |
[/QUOTE] |
We installed a second NVIDIA graphics card, (slot 2) the Core and Accel PT cards (slots 3 & 4) and so far so good.
The system will be set up for 32 AES outputs. I'll have to add some audio tracks and see what happens. Thanks...
I don't mean to be a pain but part of the reason folks just hate to call digi tech support is that the first thing they will ask you to do is rip apart the system. It doesn't mater what your problem is. You can be calling for what you later find out on the DUC (the best PT recourse anywhere) is a known issue with a straight forward workaround or fix, and tech support will have you pulling cards and yanking software.
It is just no plausible that a bus master card like the Fuse pumping a video stream is not at least as PCI hungry as a "video" card that has more memory and is working natively with a monitor. I guess the jist is that ask your fellow users because digi will not talk to you if you use the card. But you will have a large group of folks who are doing the same thing and will talk to you. The Igniter by the way even though "supported" would not allow me to run a full track count. I would be very surprised if a video card had more of an impact. You could go to the Mojo but Digi has an unfortunate history of orphaning their video options so that's sort of risky. And I apologize for jumping on you but that was such a typical Digi company line, it pissed me off. I am grateful you guy's are monitoring and responding, even if I don't like some of the answers. Quote:
I have however had some firewire -6085 errors. Got them a lot more when my third display's res was set too high (guess it was dragging too much data down the bus) and this would throw the firewire buss. I would however one day like to try getting a PCI-e firewire card so that I can get the MBox2Pro off the main firewire buss (and allow FW800) but that's a different issue. So coming back to your question, you might want to make sure the specific model of the second card you have is compatable with the MacPro - see Apple website?? Hope some of this helps. Regards, Mark
Mark Franken, MPSE Dialogue editor/supervisor IMDb Creator of 'EDI' applications for sound post editors www.soundsinsync.com |
Doing proper tech support is working with 'known quantities' and determining the source of the problem by process of elimination - you start with the obvious stuff first, in this case it would be the second video card - and I have a huge database of calls supporting that statement. Having a tech spend hours trying to get a system working that has an unsupported component and which could end up going nowhere is an unwise use of their time - and a disservice to those who follow the compatibility documents and are having a problem with a supported and compatible system who may be waiting to talk to someone. I've seen this situation time and time again and I'm only trying to make it clear how prevalent problems with second video cards are. The situation with something like the Fuse is that Pro Tools is coded specifically for that card and to handle the PCI data in an efficient manner. For us to take the time to provide this capability with the hundreds of other graphics card out there - well, let's just say that not a whole lot else would get done. Quote:
So that's what I'm here to do. I'm sorry if you feel differently about it, but I have to at least make the attempt to warn people about what they may encounter. |
EMI Noise: Graphics card to HD Native card | jacknprewitt | Pro Tools HDX & HD Native Systems (Mac) | 0 | 10-19-2013 09:02 PM |
HD Native Card Possibly Fried My Graphics Card | witrelo | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-14-2011 11:46 AM |
Graphics card for G4 800 gone bad | MidnightFlyer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-25-2007 07:43 PM |
What graphics card are you using? | Calvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-29-2004 10:00 AM |
Which Graphics Card for 2 LCD use? | timcissell | Pro Tools TDM Systems (Mac) | 2 | 07-25-2002 07:38 AM |
