Not getting good guitar sounds using amplitube
Hey i have a good guitar(77 Starcaster). I have the 002 rack
I plug the guitar directly in the back in one of the preamps I can never get a good sound using amplitube. Any tips. Do you have to change all the settings in amplitube to get a decent sound... Ill post an example later. |
Re: Not getting good guitar sounds using amplitube
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
you're never going to get the same kind of sound with amplitube like you can with micing a good amp.
www.klarityrecordingstudios.com |
Sign up for all things....AWESOME! Kris May the music move you |
Do you have Amplitube2 or AmplitubeLE? The LE version doesn't even compare to the full version. I had to really tweak the LE version to get a sound I like. The full version has tons of good tones.
BTW: if you are using the LE version, I usually used two instances of it and layered the tones. I would run the output of my guitar channel into two buses with AmplitubeLE on each one. Try a clean tone mixed with a distorted one, etc....
"Sometimes having limits keeps you sane"- Albee1952 |
Let's not forget that a crappy guitar might not sound good through any amp (or modeler). I have a much easier time getting a good sound from a good guitar and a crappy amp than the opposite. This is why my studio is stocked with a Gibson Nighthawk and an Epiphone Sheraton (poor man's ES335 - same woods & pick-ups), covers most of the bases. And for backing guitars if it's a good guitar bad amp situation, I don't hesitate to fire up a modeler and I always track a DI off the guitar.
edit: Ah I didn't see that it is not a crappy guitar. Still maybe it's the wrong guitar for what you're after. |
I use GR2 and can get pretty decent tones - however, never as good as using my CAE 3+ preamp rig though a decent mic..
Tim.. |
You say you're plugging directly into the 002R.
Are you using a DI box? If not, there's an impedance mismatch that will kill the tone. The guitar is expecting a high impedance input, typically 100Kohms minimum, whereas the MIC inputs on the 002R are around 600ohms. I've not used Amplitube, but I have used Guitar Rig, WAVES GTR with the 002R and a Radial Engineering PRO DI with great success. I hope this helps... Larry |
Does anyone know the impedance settings for the MBox input options - Mic, Line and Inst??
Tim.. |
The inputs on the Mbox1 have a setting for instrument level input. I don't know about the rest of the Mbox line.
My guitar sounds good again. | Terry Wetzel | Eleven Rack | 1 | 10-27-2011 04:48 PM |
Amplitube Sounds | Dr.Seuss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-31-2004 02:35 AM |
recording guitar sounds not so good | platinumx99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 06-22-2003 05:30 PM |
good guitar sounds | djc8902 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 05-08-2003 05:27 AM |
getting good sounds with amplitube..how do i do it? | djc8902 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-23-2003 07:01 AM |
