Problem with Custom Plugin Parameter Layout - S3
hi everyone
in eucontrol settings i have "Open windows on workstation when knobs assigned from DAW click" set to Channel Mode Knobs. this is great for when i want my s3 to "chase" me around the screen, always displaying what's active on the knobs. the problem is that most Dynamic plugins don't read the custom plugin parameter layout when the plugin is selected using this method. when selecting the plugin using other methods on the S3, the custom layout works perfectly. any insight? philip |
Re: Problem with Custom Plugin Parameter Layout - S3
oh, this is true on the S1 too
this problem also persists with plugins categorized as EQ. you can't make the custom layout follow you when in Channel Knob Mode via the setting i described in the OP
SOLVED
for anyone looking for the solution. click the "show eq/dyn plug-ins on surface as inserts if there's an Insert Custom Map" fixed! |
Product Idea - Custom Command to change parameter views | sjgam | Avid S1, S3, Dock and Control App | 0 | 11-04-2019 06:26 AM |
Knob Module Parameter in Layout Mode | Bill_Meadows | Avid S4/S6 | 12 | 08-30-2017 07:58 PM |
Custom parameter to knob assignment | RyanC | Avid S1, S3, Dock and Control App | 2 | 06-22-2016 03:42 PM |
MIDI / Plugin parameter question | Hawk570 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-09-2010 08:56 AM |
MC Control-Moving custom layout between units | anotherchrisperry | Pro Tools TDM Systems (Mac) | 0 | 11-03-2009 08:27 AM |
