Old 02-25-2003, 04:30 PM
Mikchek Mikchek is offline
Default Footswitch recording.....I hear it but see no waveform......
I don't understand what I should do....I can hear it....but when I look at the edit window I don't see a wave form....just a block of white.....
Mikchek the Emcee
www.mikchek.com
Old 02-25-2003, 04:40 PM
AverageJoe AverageJoe is offline
Default Re: Footswitch recording.....I hear it but see no waveform......
Correct me if I'm wrong but to be using a footswitch you must be in Auto-Punch mode.
When in Auto-Punch, you won't see a waveform until after you press stop, then the waveform will draw.
Old 02-25-2003, 05:16 PM
you are right AJ....but I am in auto punch mode.....when I'm finished recording that is when i see the white block with no wave form in it....
Mikchek the Emcee
www.mikchek.com
Old 02-25-2003, 05:29 PM
hmmm... and you don't hear anything when you play it back? (make sure you take it out of record).
PT can sometimes screw up the waveform rendering on the screen even though the audio is there and alright.
What version of PT are you using?
Old 02-25-2003, 05:49 PM
Just to be sure.. do you have the track set to display blocks or waveform?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 02-25-2003, 06:48 PM
Yeah, uh... umm... I was gonna say that too....
DOH!
That's gotta be it.
Is that the issue?
Old 02-25-2003, 06:59 PM
yeah I have everything set fine....if I just click the punch in...it works fine......it is not until I use the footswitch that it starts messing up and not displaying the waveform on screeen......I CAN HEAR WHAT WAS RECORDED.....I just can't see the wave form.....and once I use the footswitch it consitently does that even if I click record with the mouse.....could it be the type of footswitch I am using?.....do you need a certain kind?
Mikchek the Emcee
www.mikchek.com
Old 02-26-2003, 01:17 AM
byteme byteme is offline
<font size="2" face="Verdana, Arial">Just to reiterate, make sure the display on the track is set to WAVEFORM not BLOCK. That is the only thing that makes sense.
AJ [img]images/icons/wink.gif[/img]
Old 02-26-2003, 05:57 AM
Where would I find that at?......I guess I could look around....I have a good ideea of where you are talking about.....but I'll just ask to make sure..
Mikchek the Emcee
www.mikchek.com
Old 02-26-2003, 09:48 AM
In the edit window on the track, there is a pull down below the input and output routing. The options are Waveform, Block, Volume, Pan etc etc...
Can't hear track I'm recording on but can hear all others Durstlaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-14-2022 01:24 PM
Footswitch recording capability for 003 Rack and Pro Tools LE 8.04 dan2004 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-01-2011 07:32 PM
Can see waveform but can't hear audio missmbc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-17-2011 08:18 AM
control recording with footswitch liksvette MIDI 0 11-17-2005 08:59 AM
Anyway to use the footswitch to activate recording? dallashiphopdotcom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-29-2002 12:16 AM
