Apogee Rosetta with a Lucid 9624 D/A converter
Hey,
I'm about to purchase an Apogee Rosetta. That's all I'm getting for the time being; however, I do have a question about later purchasing a D/A converter. I understand the Rosetta has to be the master clock in my Digi setup. I don't anticipate a problem with that now. But later, when I add a D/A converter (probably the Lucid 9624 DA), will everything still function properly? In other words, will the Lucid be happy slaving to the Rosetta also? I am eventually envisioning a mixing setup that will allow me to have two channels of sends and returns that don't have to go through the Digi converters so I want to be sure my A/D and D/A converters will all work at the same time. Does anybody have a similar setup? Any suggestions? Thanks, Michael Bell |
Re: Apogee Rosetta with a Lucid 9624 D/A converter
Why not just get an AD/DA now? They'll both run off the same internal clock (which is better) and it's probably cheaper in the long run.
You would probably spend less money if you
just save up and purchase an Apogee Trak 2 with the optional D/A card. www.altomusic.com sells them for $2700. This way, you'll get 2 world class mic pre's and 2 channels of killer A to D and arguably the best master clock you can buy, all in one unit. Add the optinal D to A card and you're fully set!
Pete Weaver - Half The World www.halftheworld.cc - Will appeal to fans of Fuel, Evanessence, Staind, Sevendust. |
Thank you both for the suggestions.
You are both proposing an interesting idea. I'll have to think about that. I just purchased a two channel pre-amp (Great River MP-2NV - still en route) so I'm not sure I'd get the full value out of having a Trak 2 in my rig. How good are the Trak 2 pre's? Are they in the same neighborhood as the MP-2NV? Also, I'm not specifically looking for D/A capability right now. It would be nice to monitor through such a unit, but my real thinking was for future needs. For example, when I can scrape the money together for a high-end compressor, then I might want to use a send to compress drums or even the whole mix. However, I might not have the money for that leap for another year or so. I just wanted to make sure that I wasn't permanently ruling out the possibility of adding a D/A converter in the future by going with the Rosetta. So I guess I'm still wondering whether there would be any specific problems with clocking the Digi 001 and a D/A converter off the Rosetta. Thanks! |
Get this: http://www.audiomidi.com/common/cfm/...Product_ID=853 ...nuff said.
I thought I'd update the post after additional research in case any body else has a similar question in the future.
I spoke with Samara at Mercenary Audio and confirmed that one can run the configuration I proposed. The Lucid D/A would clock off the S/PDIF output (or ADAT optical for that matter). Thus, it is possible to have a Rosetta A/D on the front end and an independent D/A converter on the digital output. |
It would have to clock via the audio inputs ..... it doesn't have a WC input. In any event I bet it would be a great sounding system.
Tony
___________________________________________ Mac Pro 2010 2 x 2.66 / 40GB RAM / OSX 10.13.6 / PT2020.5 / Metric Halo ULN-8 |
if you own both converters your rocking dude good luck on your tracks next step is a good mic pre buy it used ther just as new [img]images/icons/wink.gif[/img]
another option would be to use a master clock generator and connect the outs to the clock in of your AD and DA converter.
Apogee Rosetta 800 or Lucid ADA 24? | phanatik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-25-2004 04:14 AM |
Apogee Rosetta 800 vs. Lucid ADÅ 8824 | phanatik | General Discussion | 0 | 02-17-2004 04:09 PM |
LUCID AD9624 vs APOGEE ROSETTA | cane | Pro Tools TDM Systems (Mac) | 31 | 03-27-2003 02:03 PM |
converter reccomendation -- LUCID A/D 9624 Stereo 96k | Allen Hallada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-26-2003 12:46 AM |
Apogee PSX-100 & Lucid 9624. Which is better? | cookiemonster | General Discussion | 3 | 09-23-2001 06:15 PM |
