Template wont save
cant save template...using current software on M2 mac mini
I get this pop up - Could not save as Sugar Session Template because Assertion is "Users/autobid/gitlabci/PT/release/2023/r4/ProTools/NewFileLibs/Sys/Sys_FileLoc.cpp, line 162 any help appreciated |
Re: Template wont save
Please try checking your documents folder if it's set to shared and not read only. Also check other location's permission. Let us know if the same issue occurs. Thanks!
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
Hi, welcome to the community.
Are you able to save it as normal session? You can later rename it as template. Otherwise please take a look at Help Us Help You page that is linked to the forum header. Compatibility info here.
Save as template in PT 12.5 | fransmo | Pro Tools 12 | 8 | 05-30-2016 09:46 AM |
Save as template error | Riverblack | Pro Tools 12 | 2 | 08-24-2015 07:58 PM |
Can't Save Template PT 11.1.3 - OSX 10.9.2 | gtodd876 | Pro Tools 11 | 2 | 12-16-2014 05:07 AM |
Can't save template on PT 10.3.2 | Blackers | Pro Tools 10 | 4 | 12-22-2012 05:17 PM |
Is it possible to save PT as a template? | Imagine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-12-2003 04:46 PM |
