Feature request: “Mute Record-Armed Tracks while Recording”
It would be great to have this feature included in the next update, for setups using Audio Interfaces with Direct Monitoring (for zero latency).
Feature request - on Preferences: “Mute Record-Armed Tracks while Recording” That feature has been available in Cubase and Nuendo for a long time. I'm aware of several workarounds and I'm actually using one but it would be way easier having that option on the Preferences > Operation (Record) settings. Just my 2c. |
Re: Feature request: “Mute Record-Armed Tracks while Recording”
Isn't that LLM?
Close, but not the same. That's one of the workaround for Core Audio interfaces but not the same as just Muting the Input when Recording. You can't have the track set to a bus out and get LLM). But...
What I found out: First I set the track to a physical, unused, spare output (I called Bypass), then I "added" the bus output I'm using. That works perfect for me but it is not ideal. Please let me know if I missing something else here. As per latest manual (p. 586) << Low Latency Monitoring HD Native, 003, 003 Rack, 003 Rack+, and Mbox Pro systems can use the Low Latency Monitoring option to record with an extremely small amount of monitoring latency, to as many tracks as each system supports. Likewise, certain Core Audio and ASIO audio interfaces that have a built-in mixer can use the Low Latency Monitoring option. Only tracks with inputs set to a physical output (not an internal mix bus) use Low Latency Monitoring. >> |
Mute Record-Armed Tracks While Stopped not working | wyman | Pro Tools 12 | 5 | 01-27-2018 01:51 PM |
MIDI Mute Record-Armed Instrument Track? | msalsbery | Pro Tools 12 | 1 | 11-02-2017 01:53 PM |
2 region mute problems (Feature request?) | Felix Rost | Pro Tools TDM Systems (Mac) | 2 | 05-01-2009 10:42 AM |
record armed tracks mute problem | lightning ad | Post - Surround - Video | 2 | 05-26-2005 03:05 PM |
