Play From Edit Start working on one session but not another
Hi all
Hopefully someone can help me out with this: I use Play from Edit Start all the time but interestingly it's not working on an session I recently pulled up. It is still working in other sessions, btw. I've gone through and tried to make sure that all of the relevant settings I can see are matching between the two sessions and it seems the settings are matching. However, something must be different and I can certainly be missing something. To be clear, the key command is returning the playback back the the edit start, but playback is stopping almost immediately. I tried increasing buffer and no change. Throwing this out into the DUC universe to see if anyone else has experienced this problem and may have some insight. Thanks! Last edited by blacksoxsound; 12-18-2023 at 09:52 AM. Reason: more info |
Re: Play From Edit Start working on one session but not another
There might be some part of the file that got messed up. Two things you can try. One is to delete your Pro Tools Prefs and see if the same issue occurs, another is to create a new session and import the one that has issues and see if the same happens. Hope this helps Thanks!
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
Hi Tope
Thanks for your reply! I seem to have found a pattern where these are old sessions that I've been importing new data that are experiencing this problem while current sessions are not exhibiting this issue, so your advice is really spot on! I will create new sessions for these projects and hopefully that will resolve the issue. Thanks again and happy holidays! |
EuCon command for Play Through Edit Start | originalscottyg | Avid S1, S3, Dock and Control App | 1 | 09-29-2022 10:45 AM |
Session won't start when pressing the Play Icon or space bar | newcens | Pro Tools 2019 | 8 | 11-22-2020 09:38 PM |
Lag between hitting play and start working w/video | ianob | macOS | 1 | 06-13-2020 09:54 PM |
How to Edit Session Start Bars|Beats to 0 ? | taylor4814 | Pro Tools 12 | 6 | 10-13-2016 03:49 AM |
Notation view edit while in play cause play to stop working. | soybalm | Pro Tools 10 | 1 | 04-18-2013 11:11 AM |
