Tempo change not working
I've set all audio tracks to tick based and elastic audio; rhythmic for drums, polyphonic for keys and guitars and monophonic for bass. I then try to set linear tempo change in the middle of a bar (from 66 to 46 BPM), but the sound is terrible, especially the bass.
Any suggestions? |
Re: Tempo change not working
That's quite a dramatic musical challenge to try to make happen in post. Are you trying to make a sudden ritard at the end of a piece? Do you need this new super-slow tempo to continue for more than say 2-beats?
If you only need this to happen for a short moment you might be better off doing it all manually. Sustained bass notes are particularly handy to extend through editing if you zoom in and match the waveform... Just a thought.
2023 MacBook Pro 15,8 (M3 max) Mac OS 14.4 (Sonoma) PT 24.3.1.162 (Ultimate) TB Native + Omni at home Apogee Duet 3 on the road |
Yes, I'm trying to do a quick ritard just before the last two bars. I will, as you suggested, do it manually. Good tip on the bass notes. Thanks a lot. You saved my day.
Easiest way is: set tracks to elastic audio, set tracks to ticks, and use tempo operations... Much more accurate this way too.
Pro Tools Ultimate 2024.3.1 MacBook Pro 16" Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine 32 GB unified memory 1TB SSD storage Ventura 13.6.4 |
Thanks for the tip. Will try it.
Tempo change not working | JPCPT120 | Pro Tools 12 | 0 | 08-22-2021 05:43 PM |
Tempo change not working! - Please, please help! | diabolusinmusica | Pro Tools 12 | 2 | 08-02-2015 04:50 AM |
Tempo change causing midi volume to change plugin output | tgrfox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-05-2011 01:08 PM |
Need to Change tempo but without changing existing midi data tempo? | Einsteinwannabe | Pro Tools M-Powered (Mac) | 2 | 09-18-2010 06:58 AM |
Ramping a Tempo Change (interpolation or discrete tempo points) | edgarbc1 | Tips & Tricks | 3 | 02-18-2009 12:55 PM |
