Old 03-30-2023, 07:32 AM
MPizzaMusic MPizzaMusic is offline
Default 2023.3 Aux IO Bug
Working strictly with music, I've been using HD Native as my main playback engine and then using the Dolby Audio Bridge output as an Aux I/O to send to the Renderer. Have had no issues on 2022.12, on this new version I get constant -6172 errors telling me to increase buffer (already maxed out,) remove plugins (happens with no plugins) or make sure clocking is correct (it is, using single MTRX Studio working at 48k.) Like I said I've had zero problems on the last version of PT, this is new issue that has come up since updating to the latest. Happens on both Rosetta and Native.
I first noticed this issue because I had to make an additional edit to a project that was started and completed on 2022.12 last week. When I reopened on 2023.3 it worked fine at first, but after a resetting my computer the issue started and hasn't work at all since then, even on blank sessions.
Running Mac Studio (M1 Max), 64gb ram, 12.6.2, PT 2023.3,MTRX Studio, HD Native TB
EDIT: I just downgraded to 2022.12 and it's working perfectly, so it seems like a 2023.3 bug.
Old 04-03-2023, 08:59 AM
Default Re: 2023.3 Aux IO/Dolby Audio Bridge Issues
A friend of mine is having the same issue with HDX as his main playback engine and SSL BiG6 as an Aux IO, so it may not be limited to the Dolby Audio Bridge.
Has anyone else experienced a similar issue?
Old 12-19-2023, 08:39 AM
iljunegate iljunegate is offline
I have severe 100% cpu problems using pro tools 2023.9 on monterey 12.7.1
The release should be supported. The problem occurs when using PT in HDX and sending signals to the DAR via Aux i/o
In activity monitoring there is the coreaudiod which crashes at 1000% making playback impossible
I tried playing the same project using the Dolby Audio Bridge directly without using the aux I/O and the problem disappeared. But I lose the enormous advantages of using the aux i/o
Has anyone had the same problem and solved it?
Mac Studio M2 Max 64gb ram 2tb
Monterey (last version)
Pro tools Ultimate 2023.12.1
Avid HDX card | 2x Avid HD I/O 16i/o | Avid MTRX studio
Api 1608 | Avid S1
Dolby Atmos certified 7.1.4 with Amphion Speakers
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
MTRX Studio Mic In's / Dolby Audio Bridge... JR Fountain Pro Tools | MTRX & MTRX Studio 60 01-07-2023 03:59 PM
22.4 + Dolby Audio Bridge going 'snap snap snap' remainanon Pro Tools 3 05-21-2022 01:20 AM
What brings Dolby Audio Bridge to HDX users? nedd Post - Surround - Video 29 01-03-2020 03:24 PM
Dolby Audio Bridge and AVB RSLAMBERT Avid S1, S3, Dock and Control App 0 11-03-2019 01:46 PM
