Old 05-16-2013, 02:22 PM
PT AJG PT AJG is offline
Default PT11 and Canopus Video Peripheral
http://avid.force.com/pkb/articles/e...eo-Peripherals
Here it says that the Canopus ADVC 100/110 "Will Not Work" with PT 11. I was thinking perhaps unsupported meant it will work but wont be supported, but it seems Avid felt it necessary to actually type out "Will not work"
So, does anyone have any solutions for replacing this? I'm finding most video peripherals are very much overkill. The Canopus boxes are so simple and all I need.
Is anyone else going to run into this? If so, any plans to share?
Thanks
Old 05-22-2013, 01:13 PM
WinTaper WinTaper is offline
Default Re: PT11 and Canopus Video Peripheral
I have the 110... pretty much used just for capture - and I typically use Adobe Premiere for that. How are you planning on using it? iMovie works well with it (capturing) as well.
-Dan
Pro Tools 2020 | Mac OSX 10.15.x
RME Ray-DAT | SSL Alpha-Link AX
2019 Apple Mac Pro 16 core / 96GB
Old 05-22-2013, 05:04 PM
Eric Lambert's Avatar
I use a couple of Canopuses as well. FW out of the computer to the box then to the TV. Great for playing .dv files within PT.
If they're retiring this box what is a similar video convertor that's approved for playing video from within PT?
Old 05-23-2013, 05:39 AM
mattrixx mattrixx is offline
Just grab yourself a Blackmagic card or box and you'll never want to see a .dv file again.
Brilliant HD visuals! Work with ProRes files and an SSD for the video files... awesome!
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 05-23-2013, 09:49 AM
Craig F Craig F is offline
my understanding is, anything that Media Composer can use form Blackmagic, AJA, Motu, Matrox, Bluefish Pro Tools 11 can use
http://www.avid.com/US/products/Symp...rdware-Options
I for one am glad it go by by
Thank you,
Craig
Old 05-23-2013, 02:59 PM
SDDP SDDP is offline
You might be glad, but a handful who are using it will have their PT11HD $600 upgrade turn into a $800 upgrade. yes the quality is better than on the BM, but HD uncompressed DV throught the C100 works/looks just as nice on a HD LCD.
Just my 2 cents
Old 05-23-2013, 03:09 PM
when we had to use them, they were nothing but trouble
they would fall offline
people would try to use non DV codecs
.dv files are bigger than the same length 1080p photoJPEG
Thank you,
Craig
Old 05-24-2013, 07:27 AM
My company uses 4 Canopus boxes (as well as a few other brands) and they've been extremely useful. DV files are larger, but hard drive space is practically free these days so that's not an issue. DV files are certainly more stable (i.e. quicker to shuffle through) than when throwing common QT movies directly into ProTools. I'm not sure how other formats rate.
The only drawback we've discovered with the Canopus boxes is the firewire delay. PT allows compensation but we sometimes forget to reset that after deleting preferences. It would be nice to forgo that step, and the conversion to DV.
Old 05-24-2013, 07:28 AM
So which Blackmagic card/box is suggested? I've looked at the Intensity Pro and DeckLink but neither is readily available to purchase.
What's your secret for getting a Blackmagic?
Old 05-24-2013, 08:35 AM
nst7 nst7 is offline
They all seem to be in stock at B&H right now. Are you outside the U.S.?
http://www.bhphotovideo.com/c/search...op+Nav-Search=
http://www.bhphotovideo.com/c/search...magic+decklink
Video Peripheral compatibility Syrcular Pro Tools 11 2 06-24-2013 11:39 PM
Media not supported by video peripheral error message meursiicc Pro Tools M-Powered (Win) 3 09-07-2009 06:41 PM
MediastationPT Satellite works w/o an Avid Video Peripheral? Dolly Post - Surround - Video 0 12-07-2007 01:25 AM
Canopus vs. DVI to Video ryan de topanga Post - Surround - Video 6 02-23-2006 10:40 AM
How to capture video with Canopus Slap Pro Tools TDM Systems (Mac) 10 10-30-2002 03:06 PM
