Footswitch recording capability for 003 Rack and Pro Tools LE 8.04
Hi, very new at this....
I am set up just to record my piano. I am not doing any editing or adding virtual instruments, etc... My set up is just for live takes on the piano. I would like to be able step on the footswitch and start recording, then step on the footswich again to stop recording. If I step on the footswich again I would like to delete the previous recording and now have a new recording. In essence I am trying to do a take and then if not satisfied with it, step on the switch again, not have to go to the keyboard, and then have a completely new take with no trace of the previous take. I am familiar with punch in and out recording. In a tutorial that I am following the technician says that you can hit play, step on the footswitch to start recording then step on it again to stop. But I am wondering if you do this several times, isn't a region created for each take? I would like to be able to delete any previous takes (regions). If I designate the recording process as "destructive" would this delete any previous takes (regions)? Also, btw, any suggestion on what to use for a footswitch (brand, type, etc...) Thanks! Dan :) |
Re: Footswitch recording capability for 003 Rack and Pro Tools LE 8.04
This is not going to happen with the footswitch jack. One option you might consider is to use a wireless keyboard/mouse, or(what I did) use a second mini-keyboard that has a track pad. I place it next to my drum kit and can run the session from there(I actually added another LCD screen on a VGA splitter too). My main mouse and keyboard are USB connections, so I use PS2 extensions with the other keyboard/trackpad setup(30 footers to go into the next room). If your keyboard is close by, then you could also get away with a Presonus Faderport on a USB extendo
Footswitch Pedal for Eleven Rack | Becharax | Eleven Rack | 1 | 01-09-2014 01:46 PM |
Using a footswitch with the 003 Rack | firsty33 | Pro Tools 10 | 6 | 12-23-2013 01:29 PM |
Footswitch For Eleven RAck +Pro Tools10 | manglio | FireWire & USB Audio Interfaces (Mac) | 0 | 08-29-2013 08:37 AM |
FootSwitch For Rack 003 | Matt Darcy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-26-2012 10:30 PM |
What footswitch should I get for my Digi002 Rack | bigbubbaj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-18-2004 08:06 AM |
