The last measure of a PT session issue. HELP !!!!
Hi Everyone !
Just recently I got some MIDI files from my friend. I imported it to my session. No problem. However, the song ends in measure 145, and to my surprise there are these empty bars after that all the way to 22000... something !!! Is it possible to erase all these empty measures,and bring the end of a session actually around bar 145 ? Any suggestions really appreciated !!! Chris |
Re: The last measure of a PT session issue. HELP !!!!
Have you just tried to delete those? What happens?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
It happens to me once in a while. I select (not in a track, but in the ruler section) from just beyond the end of the song, all the way out to the last measure. Then select from the event menu-time-cut time and click apply if it shows the correct start/end measures you want to lose.
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
BFD2 issue at measure 42 | YYR123 | The Drum Room | 3 | 09-26-2013 12:04 PM |
Adding Measure | Jel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-22-2012 05:43 AM |
Issue with going from 48K session to 96K | tim carter | Pro Tools TDM Systems (Mac) | 3 | 06-27-2011 01:43 AM |
How do you insert a measure or bar in your session??? | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-23-2007 07:16 AM |
6.4 session issue | audio1420 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-30-2004 01:42 PM |
